What is the offset for 03' Sedan wheels
Old Jan 6, 2006 | 05:27 PM
FlameOn's Avatar
Anyone knows? And what are some other things I should take into consideration when purchasing wheels for the G?
Old Jan 6, 2006 | 06:10 PM
Chico's Avatar
The OEM offset is +45 all around. Your question is very broad. My suggestion would be to spend some time reading through the threads and see the different set ups. You have to determine what you want first before your start your research.
Old Jan 6, 2006 | 06:28 PM
MikeyMike's Avatar
Rollin On Dubz
There's like a million posts on this in the sedan forum, quite a few started by yours truly.
If you search you'll find 'em.
Old Jan 7, 2006 | 05:13 AM
skeleton_cru's Avatar
Sedan
The offset depends on the width of the wheel/tire set-up. Do some research and find some wheels you like. Then find out what sizes are available and we'll be able to give you more info.
friedsqrl
18 Inch
11
Aug 9, 2015 12:41 PM
reaper76
Aug 5, 2015 10:13 AM
