Sound clip of test pipes???????
how about this:
ring.ning.ning.ning ring.ning.ning.ning...and then add the sound of vibrating cans to the mix.
That about sums up the beautiful
sound of adding test pipes.
I can say this; I've gone down this route.
If you stay catless, you'll need a custom exhaust (what I did) designed to eliminate the rasp, otherwise, an aftermarket exhaust will most likely make it worse.
But,.....there is a noticable power gain from losing the cats!!!!
sound of adding test pipes.I can say this; I've gone down this route.
i had them and took them off cause they were so annoying. sounds like bees in a coffee can if your not at WOT. changed them up for a set of highflowcats. much happier now.
heres a vid of my car w/ test pipes. http://videos.streetfire.net/player....8-40A97485B17C
