Finally got my G Sedan
Hey guys i've been on the website for about 3 months and I finally got my car.
2003 G35 M6 Sedan (black on black).....i'm very happy. I pick it up on Tuesday and I start modding it on Thursday (smile)...I will be posting pictures by the end of the week..Question for everyone though. What offset are guys using with 20x9 and 20x10 rims? Thanks for everything
jdm4eva
jdm4eva
jdm4eva
jdm4eva
9's will be nearly impossible to mount up front, you would have to go with something like a +35 offset to clear the control arm, and the wheels would stick out hella far. Same go for the rear, but you may have more luck there. I would strongly recommend a 8.5 with around a +38 and a 9.5 in the rear with a offset around +42.
The 20's will be big anyway and tough to sqeeze in, if you can do it, you will have to roll/cut your fenders.
EDIT; CRU beat me to it, I guess he posted while I was typing. Sorry for the redudant post.
So, +1 back to you Cru...
Originally Posted by skeleton_cru
Congrats on your new G. You may want to rethink your wheel widths. You'll have better luck with 8.5/+38mm front and 9.5/+45mm rear. A 9" wide wheel won't fit in the front.
jdm4eva
Actually, you can bump up the fronts to 245/35/19 and keep the rears as you indicated above. This is the most common setup for a staggered application. Be prepared to drop your car though...since the O.D. of the wheels is less than OEM and you'll have an ever so slightly larger gap between wheel and fender. What wheels are you thinking?
I'm going to either go with Tein Flex w/EDFC or i'm going with Megan Racing..
jdm4eva
Yeah, with no drop you may want to go up to a 245/40 and 275/35, this is slightly larger than stock and would fill out the gap better. Good luck.
Hey dude thanks for the input. I'm probably going to get either Axis Milanos, Axis Pentas or i'm going to go with some Rays Gram Lights 57pro.........!!!!!!
jdm4eva
jdm4eva
There are a few sedans with the Axis Milanos. See if you can find pics of sukhi's sedan.
jdm4veva
Thanks dude......i'm goin to start searching.......
jdm4veva
jdm4veva
Post #229
https://g35driver.com/forums/showthr...ghlight=milano
Post #40
jdm4veva
jdm4veva
