Tire Pressure Monitor Sensors
Will the ones of my 17" wheel work on the 18" coupe wheel? Will they have to be recalibrated? Same question for z track wheels?
Jeff92se is right, the wheel sensors just transmit an actual pressure signal.
The wheel sensors transmit to the keyless remote entry door receiver and the minimum pressure is programmed in the BCM.
Keep in mind that if the car came with 17's it's probably set to trigger the alarm at 25 psi.
If you're going to be running higher pressures in your 18's, you may want to have the system reprogrammed accordingly.
TWASkyliner
Aug 1, 2015 11:43 AM
joedaddy1
Jul 28, 2015 02:58 PM
