Rim Suggestion
Rim Suggestion
I just got my car back from the shop due to an accident on the passenger side. Now I want to replace the whole set of rims with something thats decently priced and of course not bad looking. Any Suggestions?? and also what are the the specs for the front and back that I can run? Is staggered something I should consider?? Thanks.
I agree w/ Cru....something that's inexpensive & looks nice can yield 100's of variations on this forum. As for staggered....if you drive a lot, don't get staggered...unless $ is not an issue....staggered wheels cannot be rotated front to back for obvious reasons. Once you decide if you want staggered or not, you can get feedback on the specs.
staggered always looks good but it will hinder your pocket in the long run. if you want to run the same tire size all around you can rotate the wheels and so forth which will still look good
