Is G35S running stable in high speed?
Old Jan 3, 2003 | 03:57 PM
pestilence's Avatar
Re: Is G35S running stable in high speed?
It should... it was running at pretty high RPMs at 140MPH.
..pestilence..
Old Feb 24, 2005 | 05:05 PM
Ronso's Avatar
Talking
I've only had my G for a few weeks and I haven't driven over 100 yet but I found when accelerating from 60 mph, that 90 mph is like, 2 secs away and the car feels like a jet powered freight train. It definitely likes to go fast (as do I) and is likely very stable at speed. I guess I'll be finding out soon enough but not with my wife. She was punching me and yelling to slow down at 90. I was laughing too much to concentrate on the road so I'll just have to do it alone.
Old Feb 24, 2005 | 05:22 PM
Homeslice's Avatar
What are you looking at the oldest threads first? lol
Old Feb 24, 2005 | 07:10 PM
cato's Avatar
SouthernComfort Moderator
I have had my Sedan up to 110 mph and it feels super smooth. Nothing about it makes me feel like I could not go 120 or faster. I'm just too much of a chicken to drive faster than 110. Someday I will take it over 120.
Old Feb 24, 2005 | 09:39 PM
gnut's Avatar
Hey guys, my coupe is smooth like hot butter at 59 MPH! No noise here. Hahaaaaaaa
Old Feb 24, 2005 | 10:23 PM
lawboy05's Avatar
My 05 is darn stable....seems like 90-100 is its favorite speed. So smooth and grounded it feels like you are very well planted. I have the Sport package though, so that might make a difference.
Old Feb 24, 2005 | 11:31 PM
rekrab's Avatar
My '04 sedan is quite stable at 125mph. I just installed sway bars and it feels like a whole new car now. No high speed runs yet due to rain. This car just gets more and more fun with each mod. Somebody stop me!
Old Feb 24, 2005 | 11:38 PM
Sickone's Avatar
i have had my coupe (05 AT) to 130+ a few times, and it is solid like a rock
I commonly am around 100, no problem at all
Old Feb 24, 2005 | 11:39 PM
dbarnes's Avatar
Houtxg35driver:
To answer your question - Yes!, you will be at redline in 5th gear at 155 MPH. As a matter of fact, I am at redline at 145 MPH in 5th BUT, fortunately for me, then I just shift it into 6th
Sidelight - Don't know what all this talk about "instability" in high winds, at high speeds, in the rain, etc. is all about. When my car was 2 months old (1300 miles), I took it from the SF Bay Area to Boise, Idaho, running 94 MPH at least 1/3 of the way (that's the cruise control limit - I'm lazy , and I drove at night, with very little traffic). Was raining and storming hard most of the way, and this car was stable like a rock. Only one "hairy" moment, when I entered a long sweeping right hand turn marked for 60 MPH, and I wasn't paying attention as this was the first curve in about 40-50 miles. Wind and rain were coming down hard, so I just held firm and steady at 94 MPH, leaving the cruise alone and just holding my line, trying to not upset the balance of the car. With the wind, driving rain, and the curve, I was at the limit of traction, and I could feel the back end bobble a bit, real close to "stepping out" on me.That's the only really scary thing that's happened, and it was caused by driver inattention/error.
Being long but relatively narrow, it responds to steering inputs rather quickly, and it's easy to get the weight shifting around - smoothness is the key with this car, IMHO.
My $0.02
Old Feb 25, 2005 | 02:45 AM
skeleton_cru's Avatar
Sedan
I have an '03 sedan and it's rock solid at all speeds (0-140).
Old Feb 25, 2005 | 05:54 AM
codeflux's Avatar
150mph for a couple of miles once, running from a viper (who was too much of a chicken to follow) - pretty stable. 130mph a few times, very stable as well. just have to break gently, or else the car feels wobbly.
Old Feb 25, 2005 | 08:53 AM
LameLefty's Avatar
If you do the math --
With a final gear ratio of 3.357:1 for the sedan w/5AT (per Infinitihelp.com, I think) and an engine redline at 6700 rpm (sedan) the redline puts the rear axle turning 33.26 rev/sec. If you've got stock 215/55R17 tires, at redline you'll be making 156.22 mph. If you have stock 18" tires (245/45R18), the outer tire circumference is just a tiny bit bigger and top speed at redline should be 156.31 mph. Now if you have 18" wheels with a higher sidewall height ratio (50 or larger), of course the outer circumference of your tire will be larger and the same axle speed will result in a little bit faster car. For example, for a set of 235/50R18 tires, top speed at redline should be 161.81 mph.
This is all presuming the car isn't drag-limited at high speed, but with the low Cd it has, I doubt that it is.
Old Feb 25, 2005 | 11:51 PM
Vsix's Avatar
well, it is much much much more stable than our Matrix and A4. in fact, i found out that there are a lot more dead bugs on my car than the other 2.
Old Feb 26, 2005 | 01:13 AM
lawboy05's Avatar
Did 130 today....car was VERY stable. Man I love my G.
Old Feb 26, 2005 | 11:22 AM
  #30
emtownsend's Avatar
Originally Posted by pestilence
Kongz: The cutoff on the G35 is at 155MPH.
..pestilence..
One word: Incredible!
