19x8.5 +42
Old Mar 14, 2006 | 04:50 PM
amg35's Avatar
Florida G35 Club
Question 19x8.5 +42
Any sedan owners running a 19x8.5 wheel in a +42 offset? Any clearance and/or rubbing issues? Can you post some pics please? Thanks.
Old Mar 14, 2006 | 04:56 PM
louielou's Avatar
Im running +46 and no rubbing issues so I sure the +42 are fine. The
OEM 18's are +45.
Old Mar 14, 2006 | 05:15 PM
amg35's Avatar
Florida G35 Club
louielou, thanks for the reply. Any clearance issues with the suspension components? Do you have a picture of the rear of your G? Does the +46 give it a nice wide stance? Thanks again.
Old Mar 14, 2006 | 07:23 PM
joes954rr's Avatar
I'm running the 8.5" with the 38mm offset. I've seen someone (chico I think) running a 35mm, but I'm pretty sure that a +38mm on a sedan is as much as you can go without rubbing in the rear. I run the 38mm all the way around and love it. It's setup pretty sweet and NEVER rubs.
Old Mar 14, 2006 | 07:36 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
I'm running 8.5" ET42 on my sedan.
8.5 ET42 is as tight as you can go on the front.
It gives you 2 or 3 mm clearance on the suspension.
Rear has room to spare
Old Mar 14, 2006 | 09:04 PM
amg35's Avatar
Florida G35 Club
Thanks inTgr8r, I appreciate the info. My G is lowered with the same components you have so I should be safe. Ever have an instance where your tire rubbed the suspension?
Old Mar 14, 2006 | 09:54 PM
Texan1's Avatar
Q50 Red Sport 400 RWD
Rear: 19x9.5 +40 with a 275 tire will give you that nice full-fender look.
Old Mar 14, 2006 | 11:39 PM
perry05G35's Avatar
I am running +35 all around anything lower would probably stick out too much +38 or +35 will give you an aggressive look I love it.
Old Mar 14, 2006 | 11:53 PM
louielou's Avatar
I will be adding 5mm spacers to my wheels this weekend so they can stick out a bit more.
Old Mar 14, 2006 | 11:55 PM
codeflux's Avatar
i have 19x8.5 +43 front and 19x9.5 +43 rear - no rubbing whatsoever. perfect offset.
Old May 14, 2006 | 09:13 PM
vrsc's Avatar
I have 19x8.5 +45 offset on all 4 corners and dropped on a 350Z suspension with no rubbing issues
Old May 14, 2006 | 09:21 PM
G35sedan03's Avatar
i'm running +42 all around on 19x8.5 with 245/35 tires. lowered on tein basics, never had any issues. You should be fine with +45 to 46.
Old May 18, 2006 | 04:29 PM
Simi_G35's Avatar
I am running 19x8.5 at +35 all the way around. Lowered on Eibachs, no rubbing at all. 245 tires. Pics can be seen here: http://www.mainstreamracing.com/gallery/SimiG35
Old May 18, 2006 | 07:56 PM
vrsc's Avatar
Simi, looks nice. how much did the Eibachs drop you?
jsimonk
Dec 22, 2023 03:49 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
EPG35
Aug 16, 2015 04:52 PM
T_bull
Dec 29, 2003 11:06 AM
