smalll hiss/clunk noise at startup?
Old Sep 5, 2003 | 10:42 PM
gte389k's Avatar
Just bought a black/black 2003 6spd sedan and love it. I've got ~1300 miles on it, and have noticed a small hiss/clunk noise coming from the engine compartment. The noise lasts about a half sec to a second, and usually occurs within the first 10-15 secs of car movement after the car has been started up. Even with the a/c and fan off, it's still there. It hasn't caused any problems with anything functioning though--almost as if it's normal. Sounds like a spring vibrating, or some automatic valve opening/closing. Only does it after the car is started/moved after sitting cold for a while. Any ideas?
Thanks in advance!
Old Sep 6, 2003 | 11:59 AM
mtn's Avatar
mtn
Re: smalll hiss/clunk noise at startup?
There is information on this topic in everyone owners manual. It is the VDC or ABS system self test. Every G owner should be famaliar with their owners manual. Hope this helps. There was a similar post on this subject earlier this year.
Old Sep 6, 2003 | 03:02 PM
gte389k's Avatar
Thanks. I had read somewhere else on other vehicles that the ABS self-test could make such a noise. So, this must be what it is. Again, it's independent of engine rpm and only occurs as the vehicle begins to move, so it can't be engine-specific. Plus, it sounds almost intentional/normal.
Thanks for the help. I'll go back and check the owner's manual.
Temporary solution: I've observed that if I crank up Van Halen to 100+ dBA on the G35's sound system, I don't notice the noise anymore.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
