does Nismo cams fit 2006 G35 Sedan??
Old Apr 10, 2006 | 04:21 PM
G35s-Q8's Avatar
As i said, can i install nismo cams for the 2006 G35 sedan ?? did anyone install them ??
I need help because i have a set of nismo cams and i don't know if i should install them, i bought them for my 350z, but if they'll fit and idle like stock i'll install them, if not i'll sell them (can't install them on 2006 350z either).
Old Apr 18, 2006 | 09:10 AM
jimmykce1's Avatar
It should fit since the 350Z has the same engine.
Old Apr 18, 2006 | 12:20 PM
FenixL1P's Avatar
you got nismo cams but won't install them on your z?
cams are quite pricey though.... they cost more than a rebuilt 22r motor for my toyota pickup... (with the 22r, i get a 98 hp gain.... from zero that is)....
Old Apr 18, 2006 | 01:49 PM
Jeff92se's Avatar
Red Card Crew
They might phyically fit. But you should confirm the cam profiles. Nissan might have changed them in the last few years especially if you have a 6mt rev up version.
But you have to be careful about the idling adjustment issues of the newer engines. It's not so easily adjusted in the newer VQ35s.
Old Apr 18, 2006 | 10:06 PM
RetAF's Avatar
Might also be some issues with the VVT differences. Getting pretty hi tech. I wouldn`t try something unless you are positive it will work!
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
BlackGee35
Jul 23, 2015 01:36 PM
LoSt180
Jul 15, 2015 08:31 AM
ResoG35Sedan
Jul 14, 2015 10:30 AM
