question about lowering springs
Old Apr 19, 2006 | 04:49 PM
TheTrance's Avatar
Can i just lower the front of the car and keep the back a higher (stock)?
Old Apr 19, 2006 | 05:19 PM
Clean G 4D's Avatar
You want to even up the gap?
Sure, its not a problem... just swap in the coupe's front springs.
Old Apr 19, 2006 | 05:22 PM
GLuXuRy's Avatar
im sure it wouldnt hurt... just dont go to low in the front or else it will look like a hot rod ... or you can do that and tub&slick the G with some massive MT tires
Old Apr 19, 2006 | 05:35 PM
TheTrance's Avatar
so the coupe front springs will fit with no problem? i have 18x8.5 +38 on the front wheels and 245/40/18 tires
Old Apr 19, 2006 | 05:51 PM
Clean G 4D's Avatar
350z and coupe springs fit the sedan ... however be careful of how much they will lower the sedan. <= there is a sticky in the suspension section that can help you with this.
Since you only want to change the front springs, (most likely to even the gap with the rear) the coupe's front springs should be fine. They should bring the front down 1/2".
Old Apr 19, 2006 | 09:32 PM
TheTrance's Avatar
Thanks CleanG4D just looked at that... one thing though...so can i just get the coupe/350z springs without replacing anything else?
rezendvous420
May 31, 2020 01:26 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
