yet another offest question...
Old May 1, 2006 | 07:32 PM
heyitzalex's Avatar
im wondering if an 8.5 +48 offset in the front and a 9.5 +43 offset in the rear would work for my 05 sedan, dropped on revised z springs and dspecs
Old May 1, 2006 | 07:33 PM
GLuXuRy's Avatar
i thought sedans offsets can get in the 30's range? i could be wrong
Old May 1, 2006 | 08:00 PM
Chico's Avatar
In the front you'll probably hit the suspension if you mount a 245 tire, if not, you'll be mm away from it. Plus it will not be flushed with the fender. I'd definately get 10mm spacers. In the rear you'll be ok with 275 tires.
Old May 1, 2006 | 08:06 PM
bert039's Avatar
The rear wheel offset is good.
For the front I'd definitely get a spacer. I'd get a 10mm spacer for the front. I've checked around for myself and there's only 2 options. Either get a Project Kics or Eibach, unfortunately H&R doesn't make 10mm spacers.
Old May 3, 2006 | 03:56 PM
klg35's Avatar
you can reference off this:
18X7.5 offset 45 w/ 245/45/18s.....BARELY cleared front suspension....i mean you can probably fit two pages in there.....rear was no problem....... looks way tucked though...
18X8 offset 30 w/245/45/18s(Z track wheel)....front cleared w/no problem.....
this wheel/tire combo has it flush with fender.........if anything, i might go to 235/45 tires in the future........the 245/45 up front seems too much tire
hope this helps.
Old May 3, 2006 | 04:41 PM
FenixL1P's Avatar
what size rim?
if 19 x 8.5 w/ +48 offset then you will have interference with tire sidewall and suspension arm..... especially with 245/40's up front... a 5mm spacer can make room for clearance though....
Old May 9, 2006 | 06:55 PM
heyitzalex's Avatar
will 5mm enough or will the wheel still be too tucked in? i may seriously get these wheels and I need to know.
Old May 9, 2006 | 08:10 PM
FenixL1P's Avatar
search for posts by EQUATE and see if you like the look.... he's got m35/45 sport rims (19 X 8.5 with 50mm offset) and 245/40s up front.... it appears to be flush with fenders to me....
BlueBelleG35x
Jul 23, 2015 02:10 PM
G SEDAN
Feb 13, 2007 11:05 PM
Clean G 4D
Intake & Exhaust
91
Nov 26, 2006 12:00 AM
Railgunner
Nov 10, 2006 09:11 AM
waterp7
Nov 6, 2006 06:44 PM
