stop tech bbk w/17" OEM'S ?
Old May 3, 2006 | 12:20 PM
finallystylin's Avatar
Does anybody have the 13" BBK with 17 or 18 OEM wheels? Currently have BBK with 20" aftermarket wheels but had to use a 20mm spacer. Not liking the set-up so may go back to oem until I find what will work w/o spacers.
Old May 3, 2006 | 01:05 PM
codeflux's Avatar
13" BBK will *not* fit with any 17" rims. it *may* fit with 18" rims - you need to try the fitment templates posted on stoptech's web site to see if stock 18" rims will fit.
Old May 3, 2006 | 04:20 PM
thanks. Looks like I'll be selling the 17's and the aftermarket 20's.
Old May 3, 2006 | 04:46 PM
bigwilly's Avatar
That is not totally true the 13" 332mm brakes will fit 17" wheels as long as the offset is right. Having said that the stock 17"s with +45 offset do not work I've tested with the stoptech template. The diameter / curcumference of at 17" rim provides enough clearances just offset that messes things up. You will need at least a 1.5" of space from the rotor hat to the spokes with clear most of the BBKs.
Old May 3, 2006 | 05:47 PM
jran76's Avatar
I had the 13" kit on my 350Z with the 17" wheels and they fit (barely), the G 17" will not work...
One thing I may do is pick up a set of 17" Z wheels for cheap, just to have in case I need them.
Old May 3, 2006 | 07:48 PM
bigwilly's Avatar
I'll trade someone 5xG 17" wheels and tires for 4xZ 17"s Thats the only thing that is preventing me from a BBK. I have my 17"s as my winter setup and don't want to drop a pile of cash on another set of wheels for winter just to be able to fit bigger brakes.. arg.
miata007
Aug 17, 2015 04:36 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
mushu
Jul 15, 2015 03:55 PM
