Tire Rack Experience!
Old Dec 14, 2006 | 03:10 PM
dopey's Avatar
Originally Posted by kring
putting some guesstimates to this (r after number means reoccurring)
$30r + $30r VS. $550 + $260 + $100 + $40r + $30r = It cost $910 more to have separate wheels. And I'm going on the low end here for the wheel cost.
Annual reoccurring costs are $120/yr (2x $30+$30) VS. $140/yr (2x $40 + $30). The difference is $20.00 a year in MORE.
Taking the initial $910 outlay of expense, and a higher annual cost, there's no point to doing this. Even if you swap out sets yourself instead of paying for the service, ($80/yr) it would still take it would take over 22 years to offset the inital cost....
[stuff snipped]
To keep apples to apples, you can't eliminate the TPS sensors, so I don't see that as a valid argument to offset the cost.
So you're right, apples to apples, because of the TPMS cost, it's not that good of a deal unless you keep the car for a long time. The problem with your calculations are that you assume apples to apples. Snow tires are not the same as summers. Right away that rules out apples to apples. If you have to "compromise" performance to get good snow driving tires, you're likely willing to compromise on other things for the 5 months of the year you need snow shoes.
To give you my numbers (I'll use the same mounting/balancing costs that you used)
Wheels = $300. I got cheap 17" rims. They're not super good looking, but they're effective, they use a universal bolt pattern so I don't have to remove the pin every time they swap wheels.
Initial cost with separate rims.
Wheels + mount + balancing. I originally wanted to go to tirerack for my rims and tires, but htey wouldn't sell me anything, so instead i went to a local tireshop. wheel swap costs are free. My tire place does rotations for free which includes winter/summer swaps. The place i would have used for tirerack also does the same thing, so no swap cost.
$300 + $30 + $30 = $460
Other than new tires, no yearly maintenance cost
Swapping tires on the same rims
$30+$30 twice a year. Most places I use include swapping in their mounting/balancing costs.
So basically 120 a year.
In four years it pays for itself. Beyond that. the numbers above don't include additional benefits that are not as clearly tangible. I have a G35S which has 18" rims stock. Gettng 17" rims means it's cheaper if i bend a rim on minnesota winter potholes. Also, 17" tires tend to cost less than 18" tires.
Luisgalvan33
Jul 19, 2018 08:16 PM
derres
Aug 28, 2015 03:27 PM
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
j_mullet
Aug 26, 2015 10:49 PM
Luisgalvan33
Jul 28, 2015 05:37 PM
