Adjusting gas pedal sensitivity
Old Jan 19, 2007 | 02:35 AM
achau's Avatar
Hello,
I just picked up my new 07 G35 sport a week ago. Love the car. Only thing is the gas pedal seems to have some play. During the 1st inch of gas pedal travel, the engine revs slightly, then when I have the gas pedal depressed pass the 1 inch mark, it suddenly revs much faster than how I would expect based on the amount of pedal I am giving it.
Has anyone experienced the same? Is there a way to adjust the sensitivity or play of the gas pedal?
Andy
Old Jan 19, 2007 | 02:40 AM
akachi's Avatar
i think u just got to get used to it..
when i picked up my '06 coupe.. the car jumps with a slight push on the gas.. but now it doesn't, i got used to it..
Old Jan 19, 2007 | 02:41 AM
SFG356MT's Avatar
Welcome Andy. That sounds like a new issue and maybe only with the 07's. Check it with you dealer.
Old Jan 19, 2007 | 03:17 AM
terrycs's Avatar
Also keep in mind it is drive-by-wire, so the car's ECU is really learning how you drive. Try giving it a little time to get to know you!
Old Jan 19, 2007 | 04:20 AM
huhuh2's Avatar
I also experience the same thing.. although I haven't monitored my RPMs on starts, but there is definitely some play in the pedal before it translates to a surge in forward movement, resulting in a kind of lurching start. I figured this is not an issue with the car, but just a characteristic of the car that I've gotten used to. I can make smooth starts now but still there is some delay (i.e., I can't trail the car in front of me as close as I used to from stops).
Old Jan 19, 2007 | 06:01 AM
Madison_Malia's Avatar
That was the first thing I noticed when I got behind the wheel of the new G for the very first time. I was like, "geez, this thing is sensitive." But then I really liked how responsive it was to the slightest of touch.
Old Jan 19, 2007 | 08:12 AM
G35Now!'s Avatar
Moderation-free
My Max was a bit like this (also drive-by-wire), and the G is just more so. It's seriously binary, but you get used to it; I either roll on slowly, or just punch it past the step
Old Jan 19, 2007 | 09:05 AM
randman's Avatar
Yes, I noticed also that there's a point, as you first step down on the accelerator, where the accelerator is a little harder than other cars to push down, and if you're not too gentle in pushing it down, the car accelerates a lot. There were a few times at first when I accelerated more than desired coming off a stop light. I'm getting used to it, and learning to give it that "gentle" touch to give my passengers a little more comfort...
Old Jan 19, 2007 | 11:26 AM
terrycs's Avatar
I orginally had "surge" issues at first, but not anymore. I've got about 1600 miles on mine now ... maybe I just got used to it. My wife never noticed the surging but then, she only recently started driving it .
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Fox843
Nov 7, 2015 05:43 PM
AL8782
Oct 3, 2015 10:26 AM
Hogbone
Sep 28, 2015 06:44 PM
