I can see no difference when fog lights are on.
I've had my G35 for 3 days and drove it on a winding road last night. I flipped on the fog lights and couldn't see any difference. Is this how it should be?
On my other cars the fog lights illuminate the road closer to the front hood and on the sides giving a wider beam. Is there something wrong with my fog lights?
Thanks,
Bruce in LA
Thanks,
Bruce in LA
I notice them as well.
They are just below the turn signals I believe, inboard of the main headlight bulge.
You can see them in the reflection of the vehicle in front of you at a red light if you blink them.
To me, it looks like they illuminate the area immediately infront of the car with a wide beam...
the fogs arent HID so they might be drowned by the head lights. ive never been a fan of fog lights being inside the headligh assembly. i like my fogs seperate. ill see a difference if im stopped infront of a wall or at a red light behind a car.
I can see a difference, but it's not very dramatic - you really have to watch as they go on and off.
The only time I've noticed a real difference with them on in any car, was when it was actually very foggy.
Some strange responses here.
The reason I say that is when I use the fog lights, it completely lights up the road immediately in front of me in a wide angle. They work darn good IMO.
The fog lights are a joke, I have tried in numerous conditions and they create a little extra light about 2 ft. in front of the car but that's it.... not enough to make any sort of visibility advantage. I was also displeased with the pattern the headlights projected, with the sharp cut off. So I adjusted up the headlights just a little bit and now I could careless if the car had foglights at all. I will note, there is a seperate adjuster for the fog light bulb you could adjust it up a bit to possibly see a difference. But with the headlights adjusted up that little bit I see no reason in wasting time, I have superb night/ugly weather visibility now.
Originally Posted by Garnet Canuck
You do realize that fog lights are designed to be aimed down and close to the front of the vehicle, as light aimed straight ahead will only difuse in a fog and DECREASE the visibility of the driver. They are doing EXACTLY what they are designed to do.
And the fact still remains the foglights are a redundancy on this car to please a market who wants a 20+ year old luxury option. HIDs make foglamps obsolete, yet the older crowd likes to hold on to that old time luxury option.
Riiiight, light is not needed two feet in front of the car regardless of the conditions outside, I am well aware that the light will difuse in fog, the idea of a foglight is to have a different beam that typically works better in fog. This is not my first car with factory foglights(its the 6th), and its fog lights are the least beneficial of the bunch.
It was quite easy to measure since you can definitely tell where the halogen fog lights end agains the HID headlights. Anyways, my fog lights projected 23' 4" in front of my car. If yours only project 2 feet you may want to get them looked at.
