X or S ??
Old Mar 25, 2007 | 10:35 AM
G35Now!'s Avatar
Moderation-free
Originally Posted by treacherous
I've wondered this myself. Doesn't the X do a somewhat emulated limited slip trick by braking the spinning rear wheel?
The sport is a limited slip and not a posi-lock type rear end, am I correct?
Limited slip delivers power to the non-spinning wheel, so if one wheel is spinning (say, out of a turn) the other wheel will get power and the G will accelerate.
VDC will stop a wheel from spinning, but that's it - it doesn't transfer power, so if a wheel spins you're slowing down. That said, the X has the advantage of delivering traction to at least one front wheel too, so you could argue that a similar power transfer is happening.
