Recording a CD to the Music Box when on short trips
Old Mar 26, 2007 | 04:43 PM
ThatsMyG's Avatar
I am building up my Music box library, so each time I am driving in the car, I throw in a CD and start recroding to the Music Box. Works fine on longer tipes, but suppose I do a 15 minute run and it only records 8 of 12 tracks, and I need to leave. The next time I start the car, and hit record, is it:
- smart enough to know it already recorded some tracks and it just needs to do the rest...
-or is it going to start from scratch and record all 12 ( ie and give me a duplicate set 8 which I will need to delete after)
In this particular case, although these are commercial CD's, they are not in the onboad gracenote database (they are new), so the track names/albums are all based on default date/times. Is that a factor? I know I can use the export/import feature to correct the track titles, but I am first curious about how the recording-to-MusicBox works when not all of the CD was recorded.
Old Mar 26, 2007 | 04:48 PM
max2k1's Avatar
I have only done a couple of CDs so far (all original CDs and was IDed by the Gracenote DB).
I had to stop both of them mid-way through and the next time around it picked up where it left off.
I don't have duplicates in the HD (or to put this more accurately, when I see a list of songs, no duplicates are listed).
Old Mar 26, 2007 | 04:56 PM
ThatsMyG's Avatar
Did you need to hit record again, or did it start recording on its own??
Old Mar 26, 2007 | 05:01 PM
terrycs's Avatar
That depends on the setting you use for recording. Default is you have to hit record again. Optional menu pick is to auto-record.
Old Mar 26, 2007 | 05:12 PM
max2k1's Avatar
I don't have auto-record new CDs turned on.
So I had to hit record again.
Old Mar 27, 2007 | 05:14 PM
ThatsMyG's Avatar
I now set the auto-record ON and it works great. Per above, it records where istleft off and creates no duplicates.
It's fast as well. While you can listen anything during the record mode, I just left the CD on, and by the time I heard the third song on the CD, it was done.
Also tried the gracenote export/import and it worked perfectly as well.
Only thing I would have liked to see is a better presentation of the index of albums on the music box. Right now, it defaults to a track level ( of the first album I assume) and you cant go up a level to see the liwt of albums. You need to find the feature to search by album to see the index , and while the list can be sorted, the fields it sorts on are not visible, so it doesnt really look sorted.
The CF works a bit differnetly. I have folders for each artist, and I can see the 'tree' of folders very intuitively.
But this is very minor in the scheme of things.
Old Mar 27, 2007 | 05:59 PM
terrycs's Avatar
If you have the MB set up to search by album, you can very quickly sroll though all your albums by using the tuning located **** to the right of the CD slot.
Old Mar 27, 2007 | 09:55 PM
MoCoG's Avatar
While I don't know what happens if you stop mid-way, I've never had a CD take more than 6-8 minutes to rip completely.
Old Mar 28, 2007 | 02:01 AM
G-Whizzer's Avatar
^^ Agreed.
I was a bit surprised to hear you didn't record the whole thing in one session.
It's usually done by the 5th or 6th song.
Old Mar 28, 2007 | 05:40 AM
ThatsMyG's Avatar
Originally Posted by G-Whizzer
^^ Agreed.
Correct. It now is done by then or even sooner, now that I have auto-record on. In my orignal scenario, it was off, so by the time I remembered to turn in on, my short run was almost over, so it didnt finish. With auto-record on it works fine.
For the first few weeks I am keeping a shoebox full of CDs in the back seat, so when I get in, I make sure to throw one or more in per trip. Too bad you cant run a 50 foot USB cable from the house to the car!
Have not tried putting the same CD in twice - its probably smart enough to know not to record again.
Freeman186
Sep 6, 2023 10:07 AM
mattdg35
Sep 14, 2015 11:28 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
Mikesta
Sep 10, 2015 05:14 PM
