07 sedan paddle shifter ?
Originally Posted by daluder
how are you using these? do you use them to slow down the car? is it better to use the breaks or wear down the tranny.
But I do downshift if I'm catching up to a car too fast (i.e. need to slow down <10 mph), or for a corner if I'm playing on back roads, etc.
so it ca put wear on the tranny?
Wont Break it if used correctly
You can play with the upshift and down shift all you want, it will only shift to the lower or higher gear when it is ready. Have fun with it. It is one big shifter kart.
with the rev-match function you are not wearing anything down. Using the downshift function on the AT gearboxes is completely safe since it has the rev-match function. The "wear" in a rev-up portion of braking is just as bad as a rev-up you take your engine through when you accelerate. If you were in an MT that would have been a little different as you would need to know how to rev-match so you don't wear down the clutch. I used the pedals a couple of time to brake myself down, but I usually try to avoid last minute brakes. If I'm approaching a light, I start slowing down in advance by simply taking my foot off the gas pedal.
Like I said though, I do it depending on driving situation, and don't expect any problems.
Originally Posted by G35Now!
This is exactly correct (good description), but doesn't mean there's no wear/stress on the drivetrain when you do it. As you said, it's wear on the drivetrain.
In short: wear? -yes | damage? - no.
That's correct. Let me rephrase myself: there is wear on the drivetrain but not "excessive" wear. In other words, you are not causing extra damage that is beyond of what the engine/powertrain were designed for.
Originally Posted by johnblaz2000
Going down a long steep hill? I would just use my adaptive cruise control. It does all the breaking for you. Plus speeding up.
Originally Posted by terrycs
Keep in mind ... you only get up to 25% braking with ICC on.
FS[SoEast]: 2006 DG Coupe Part Out - mrev2, projectors, etc
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
BasquiatPicasso
Jul 23, 2015 06:26 PM
newbdriver01
Jul 15, 2015 06:10 PM
