2007 G35 S Weight
Old Apr 11, 2007 | 10:47 PM
muscarel's Avatar
2007 G35 S Weight
I was looking at vehicle weights on nissanews.com, and saw that the specs have the 2007 G35 Sedan at about 3,530 lbs or so. It also showed the 2007 350z at 3,600 lbs. I don't get it. Weren't the Z's always lighter by a couple hundred lbs? If the weight is correct, why are 2007 350z's running 13.5s +/- and the G's are running 13.9-14.0?
Old Apr 11, 2007 | 11:06 PM
Jiggs1219's Avatar
Gearing maybe different. On a related note, the G35x is even heavier so any one know what it runs at the track?
Old Apr 11, 2007 | 11:09 PM
CrazyRuskie's Avatar
You were looking at the 350Z Roadster. Click on 350Z Coupe and the weights are much lower.
Old Apr 12, 2007 | 06:32 AM
muscarel's Avatar
Interesting. They must have them flipped. The roadster says 3,500 and the coupe says 3,600.
Either way, 50 lbs cannot be that big of a difference at the track. The gearing is identical. Everyone keeps saying that the Z is alot lighter, but I don't get it.
Old Apr 12, 2007 | 12:22 PM
mjs222's Avatar
on the note of cutting weight, does anybody know if there are any new types of glass/polymers on the horizon that can be used to save weight in windows/windshield withought killing their thermal and acoustic traits?
i just ask because it would be a double plus, as the weight is high up on the car
Old Apr 12, 2007 | 05:36 PM
Bigred14's Avatar
Transparent Aluminum
http://www.chemistry.org/portal/a/c/...inum_arch.html
Old Apr 12, 2007 | 06:01 PM
Skaterbasist's Avatar
Retired SuperMod
07 Z's are actually running 13.7-13.3, with weight around 3350-3410 depending on the model.
07 Sedans should possibly do 13.5's, but no one seems to track the 07 G Sedans as frequent as the Z's.
Old Apr 12, 2007 | 06:03 PM
I might be taking the 07 Sedan 5AT to the track May 4th. I will try to at least.
Old Apr 13, 2007 | 02:12 PM
Retired SuperMod
Can't wait to see the results.
Are you consistent at the track, or is it you first or first few times at the track?
Also, how's the track itself?
Goodluck!
Old Apr 13, 2007 | 10:47 PM
muscarel's Avatar
If the 350Z is not really 3,500 lbs like the specs from Nissan quote, then maybe the new G37 coupe is not 3,680 lbs as the sources are the same.
Old Apr 14, 2007 | 03:07 AM
Going to be my first time. My friend ran a 13.7 pretty easily with his 07 Z with a 2.2 60'. It had rained earlier and there was a 77% humidity when he ran it. The track is like 100-200' above sea level. I will let you know what happens when I go!
Old Apr 20, 2007 | 12:47 PM
mkaresh's Avatar
I use nissanews as one data source for my site. Lots of typos over there.
In general, though, curb weight specs are so shaky that I don't currently post them to my site. For example, Ford is putting a new powertrain into the Five Hundred ==> Taurus for 2008, and adding more sound deadening material. But the published curb weight is identical for the new car.
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
