CompactFlash: Don't Use XCOPY
Old May 4, 2007 | 02:43 PM
  #46
trey's wife's Avatar
My horns hold up my halo
Originally Posted by SPEEED
I was able to record a burned MP3 CD on the music box.
Please tell me that these were files that were still in MP3 format? OMG that would save me SOOOO much time.
Old May 4, 2007 | 02:55 PM
  #47
allanak's Avatar
Originally Posted by theacolyte
Bah--- I said it in a post on the 2nd page.
Musta missed it, my bad.
And if someone tells me that I can copy an MP3 CD to my hard drive I'm going to be very annoyed at how much time I wasted burning audio CDs...
Originally Posted by mikepro
cp -pR /mp3 /mnt/compactflash
Man, I HATE it when people don't use the -p option to preserve creations times. Of course, I'd probably just write a perl script to do this for me...
Do you really need to preserve the date/timestamp of your downloaded (err...backed up ) music?
Old May 4, 2007 | 03:32 PM
  #48
SPEEED's Avatar
Bad Toro
Sorry guys (and gal). That was a typo. I meant to write burned audio CD (CDAs) that was burned from an MP3 to CDA conversion.
Good catch. My remark came in response to the claim that you can burn only original CDs...
Old May 4, 2007 | 04:07 PM
  #49
ThatsMyG's Avatar
Sorry guys (and gal). That was a typo. I meant to write burned audio CD (CDAs) that was burned from an MP3 to CDA conversion. Good catch. My remark came in response to the claim that you can burn only original CDs...
Correct,,, one can copy any AUDIO CD to the music box, ie , orginals, home made copies/duplicates, or audio CD created from Mp3 flies.
Old May 4, 2007 | 05:23 PM
  #50
dopey's Avatar
recursive copy doesn't necessarily require creation time preservation. There are plenty of times when I copy something that I actually WANT the new times to reflect the copied time and not the original time.
having to burn mp3s to CDA, then rip them back sucks. The bit rate on the musicbox is already crappy enough as it is. Having to deal with it from a lossy source sucks even more. I'll stick with using my lame encoded mp3s on my ipod or cf card
Old May 6, 2007 | 11:28 PM
  #51
japhule's Avatar
Copying your music in order using Windows Copy
Hey everyone,
I think I know why you guys are having issues with Windows copy to copy files to your CF card. Just make sure that after you highlight the files you want to copy over, that you drag them to the compact flash directory by clicking on the first file and then drag it over. If you don't, then the first file going to the CF card is the file you clicked on when you did the drag and then every file after that, then it will copy over the first files and down when it gets to the end.
For example, if you highlight 20 mp3 files to copy over, and you click on the 10th file and drag them over, the order displayed in the G will start with that file.
I got my CF card today and tested it out that that is indeed the case.
I've also noticed that when you copy over a whole folder, it will begin with the first file in that folder.
Hope that helps.
Old May 6, 2007 | 11:34 PM
  #52
Gorn's Avatar
Thanks for the very cool observation! I wonder if it would work if you selected from bottom up like so:
  1. Click on last file/directory.
  2. Hold down shift.
  3. Click on first file/directory.
  4. Drag and drop.
Old May 6, 2007 | 11:39 PM
  #53
japhule's Avatar
  2. Hold down shift.
  4. Drag and drop.
Hmmm... Not sure if that will work. I don't think it matters how it's selected, just where you clicked when you drag it over.
However, if you selected from the bottom up, you're more likely to drag from first file/dir, right?
Old Jun 17, 2007 | 11:07 PM
  #54
kutrovsky's Avatar
Guys,
I compared XCOPY vs Explorer DRAG, and the resulting file entries (a HEX dump on the sectors) are exactly the same.
The only difference is that XCOPY uses "incomplete" and then renames the file and there's a "deleted" entry called "incomplete" after.
Other then that, it looks absolutelly the same.
In regards to file ordering, there are tools, that could re-order your entries in any order you liked. At least for DOS.
There was a tool from the Norton DOS toolset, that could "optimize" your directories by ordering all your entries alphabetically.
Jiggerjuice
Oct 5, 2015 02:33 PM
cmesidewayz
Sep 29, 2015 09:28 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
