How can I turn traction control totally off?
Old May 6, 2007 | 10:16 PM
aalbert's Avatar
Question How can I turn traction control totally off?
If I don't want traction control to interfear with my inputs whatsoever...what am I supposed to do?
There's times you want to use 300 horses in the wrong ways...like peeling out rear tires in standing place (with brakes on) or doing donuts. (in safe places) but none are possible to their full potential when traction control kicks in (even when you supposedly turn it off).
Old May 6, 2007 | 10:24 PM
KLASiKAHL's Avatar
VDC on/off button is located next to the trunk button near your left knee. If you're not getting the slippage you desire, change your tires. Potenzas aren't made to atomize around every turn. I have no problem letting the tail end loose with VDC off, so maybe you need to check your technique.
Old May 6, 2007 | 10:43 PM
Alan's Avatar
pull fuse
G35Now!'s Avatar
Moderation-free
+1 I haven't experienced traction control kicking back in if I turn off VDC.
Old May 6, 2007 | 11:14 PM
CarNutz's Avatar
Originally Posted by Alan
pull fuse
Which fuse... ? The one for ABS? There is no fuse for VDC since its just a couple of sensors and software that use the ABS and DBW system
Old May 6, 2007 | 11:28 PM
aalbert's Avatar
Can any of you put your brakes on and hit the gas to spin the rear wheels while standing in place? Mine does it for maybe 3 seconds then cuts back...this is ovbiously with the VDC turned off to begin with.
Old May 6, 2007 | 11:54 PM
CarNutz's Avatar
Why would you do this without a line-lock on the front brake circuit? If you are fighting your rear brakes while you are trying to spin them.. The ABS has to be kicking in as the system thinks you are trying to stop and is backing off the throttle..
Old May 7, 2007 | 01:38 AM
aalbert's Avatar
Ah okay that makes sense...I'm not too educated on ABS and how it affects a car with a DBW system. So if the ABS fuse is taken out, I'll probably be able to spin the wheels right?
Old May 7, 2007 | 11:54 AM
IvoryPearl07G's Avatar
its an ecu thing. my sentra specv did it to. If you are on the throttle and brake, throttle is cut any where from 25 to 50%. made it where i couldnt brake boost my specv at the start of a race. same thing happening on the G
Old May 7, 2007 | 12:00 PM
Fassster10's Avatar
damn those techniques just sound like horrible abuse on the G...
Old May 7, 2007 | 12:13 PM
GumboChief's Avatar
Too bad you can't rent a 2007 G35 from Avis.
I wouldn't mind doing some first hand research on your premise
Old May 7, 2007 | 02:06 PM
GNN60GT500's Avatar
Umm unless you get a line lock for only the front brakes, by buring out with your foot on the brakes you are killing your rear brakes-
Old May 7, 2007 | 05:54 PM
cup0spam's Avatar
sell your car and buy the 6 speed
Old May 7, 2007 | 06:43 PM
ttrank's Avatar
Grocery getter
The traction control will still kick on when you hit the brake even with VDC off in a 6MT. The only way I have ever turned mine off is to do burnouts at the track and I pulled the ABS fuse.
Old May 7, 2007 | 06:45 PM
GeeWillikers's Avatar
Walking The Fine Line...
Waiting for the 'I lost control of my car' thread.
