Semi Dead G35x
Old Jul 31, 2007 | 01:51 AM
ColoXMan's Avatar
Semi Dead G35x
Hi all. Started up the 2007 fully loaded G35x (2000 miles) and had a host of electronic gremlins show up (no odo, speedo, tach, climate control, turn signals, turn signal indicators, nav, not easy to turn off-hold button down 15 seconds or more, etc). Of course the stereo still worked! In short, engine ran, but otherwise ran hot in cabin (no a/c) and blind. Dealer immediately said (via phone) that it was a failed bluetooth relay/module and had seen it a few times before. Anyone else have this happen? Any other fall out I should anticipate? FYI-My 2004 never missed a beat.
Thanks.
Old Jul 31, 2007 | 09:11 AM
randman's Avatar
I also have a fully loaded G35x. This never happened with me.
Old Jul 31, 2007 | 09:18 AM
ScubaSteve312's Avatar
Thanks.
whether its really a result of a failed bluetooth relay () or not I'm positive your dealer doesnt want you using the lemon law to get compensation
Old Jul 31, 2007 | 11:08 AM
GreenGoblin's Avatar
The goblin resurrection
that doesnt sound right but to lemon law the car they have to try to fix the same thing 3 times
Old Jul 31, 2007 | 05:38 PM
Sedanman07's Avatar
Waxer
Thanks.
When something like this happens you might also try disconnecting the battery for a couple of minutes. This action sorts of reboots everything and will sometimes fix these kinds of bugs.
Old Aug 4, 2007 | 07:48 PM
ColoXMan's Avatar
Update:Cooling my heels...7 weeks (!) for part/circuit board
Problem has cropped up in some Gs and Ms according to Infiniti. In the meantime, Sedanman 07 could work as an Infiniti tech-the battery reset is a good idea and was recommeded by Infiniti. (This has also worked with my Audi allroad as well over the years). Depending on the issue, I have found with Audi you can also pull the fuse and replace the fuse to accomplish the same result, probably woulf work on the g as well...
Old Aug 4, 2007 | 08:06 PM
BlkG35Sport's Avatar
I run my G like a Russian on a weekend pass, no problems yet (5400 miles now)
P.S never broke it in to spec. I been red lining since 5 miles on the dash.
Dude you got a lemon.
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
AJC128
Nov 1, 2015 11:55 AM
dcsbh1
Oct 1, 2015 03:15 PM
Claudiu
Sep 26, 2015 01:04 PM
