treacherous
close
- Join DateMar 2006
iTrader Positive Feedback0
iTrader Feedback Score(0)
- My RideG35x
Liked:95 Times in 82 Posts
APPLIED
VEHICLES:
2006-2007 M35/45 (Y50) with Intelligent Cruise Control (ICC) Only
2004-2007 QX56 (JA60) with Intelligent Cruise Control (ICC) Only
2007 G35 Sedan (V36) with Intelligent Cruise Control (ICC) Only
IF YOU CONFIRM:
The Brake Warning Light, Slip Indicator Light, and Vehicle Dynamic Control (VDC) “OFF” Light are all ON.
ACTION:
If you have a BR FLUID LEVEL LOW [C1155] DTC stored:
Check the brake linings for wear. This code is typically stored because of low brake fluid level caused by worn brake linings. With brake application and vehicle movement code C1155 may be detected as fluid level nears the low level line in the brake fluid reservoir.
VEHICLES:
IF YOU CONFIRM:
ACTION:
Don't have this problem yet, but good to know what it is when I see it. Thanks for the info.
Quote:
exxxxxactly.....
lets wait n see if Infiniti has something in store for us aftre one year of ownership
ya know recently i turned my car on and every one of these lights were on out of nowhere...all i did was shut it and turn it back on and they were gone. No problems since.
i had it happen 3 times now.....and i DONOT have the icc.
It happens when i start it up and immediately throw it into gear. I have to stop, turn it off and restart to get them off.
