Left interior/trunk lights on / Battery damaged?
Old Jan 22, 2008 | 02:31 PM
Kach Vartan's Avatar
Okay, so over the weekend, I swapped out all of my interior lights and rear license plate lights for LEDs. It turned out pretty cool and I will post pics tonight…eventually…some day…okay, maybe. I ended up going with the 5-LEDs from Superbrightleds.com for all of the lights except some superduper single LED (from the same site) for the trunk light and 12 Leds for the front map lights. Thanks to all those who previously did this mod and posted all the information and how-to's on this forum.
Now here's my problem. In my understanable excitement to show off the latest mod to my wife and our two-year old, both of whom clearly could have cared less, I ended up leaving my map lights on and my trunk open - and therefore the trunk light on - overnight. Actually, the map lights may have been on for as long as 36 hours! Yes, very boneheaded of me.
When I went down to my garage this morning, the lights were still on, which seemed strange because I thought there was an automatic off feature after five minutes (but maybe that's just for the exterior lights?). Luckily, the car started on the first push of the ignition button, but the battery definitely struggled compared to a normal start. Do you guys think there's any permanent damage/drain to the battery? I know LEDs do not draw a lot of power, but maybe I should have the battery checked out by a mechanic? FWIW, I have less than 500 miles on the car, so the battery was otherwise new.
Old Jan 22, 2008 | 03:32 PM
max2k1's Avatar
Nah - don't worry about it.
Just drive the car around for an hour or so and your battery should get recharged back to where it was.
Old Jan 22, 2008 | 03:41 PM
RiledUp's Avatar
+1 ^
Just let the car run for a while and the alternator will charge your battery back up.
Old Jan 22, 2008 | 04:30 PM
Cool, thanks guys.
Old Jan 22, 2008 | 06:28 PM
imnotplutonium's Avatar
it just might explode.....
no the alt. will charge it up
Old Jan 22, 2008 | 08:30 PM
ABQ_G35's Avatar
Wait a minute here, doesn't anything you leave on automatically shut off after a certain amount of time, to protect the battery? I'll have to check mine now, I know my '05 did taht.
Old Jan 22, 2008 | 10:29 PM
suprajjang's Avatar
i dont think so. I had my trunk open for about 10 minutes and the light was still on when i came back. let me go check it again
Old Jan 23, 2008 | 07:51 AM
G35Now!'s Avatar
Moderation-free
Yes, that's been my experience too. Don't LED lights use a lot less power? Maybe the G doesn't register it as "power on" and doesn't auto-shut-off...?
Old Jan 23, 2008 | 09:21 AM
stinky's Avatar
+1 ;-)
Old Jan 23, 2008 | 10:41 AM
tg1234's Avatar
If you leave door, trank open I think it wont shut the light off.
tg
Old Jan 23, 2008 | 12:40 PM
ugaexploder's Avatar
yes L.E.D. technology uses about a tenth of what a normal light bulb uses for power. in fact, the audi r8 is going to be the first production car to have L.E.D. headlights. even crazier is that L.E.D.'s are created by crystals that emit light. semiconductors
Old Jan 23, 2008 | 01:57 PM
I guess it's limited to exterior lights only. Of course, I'm not going to risk checking again...at least not intentionally...
By the way, both the battery and the car ended up fine.
Old Jan 23, 2008 | 06:44 PM
ZIPPYGAS's Avatar
better check the Halogen fluid levels in your head lights as well....
Old Jan 23, 2008 | 08:48 PM
Que? My headlights weren't left on...but even if they were, how does one check halogen levels?
Old Jan 23, 2008 | 09:12 PM
ZIPPYGAS's Avatar
there should be a dip stick on each light
