Replace rear turn signal bulbs with LED's?
Old Mar 21, 2008 | 01:05 PM
wiredup's Avatar
Has anyone replaced their rear turn signal bulbs with LED's? ... And, does the G35 Sedan have a "bulb" burnt out/not working idiot light that would illuminate if I put in low voltage LED's?
Old Mar 21, 2008 | 01:10 PM
ttrank's Avatar
Grocery getter
I would bet this would work just like the 1st gen sedans.
Here is what I did. The fronts work just the same.
https://g35driver.com/forums/lighting/202609-anyone-other-sedans-hate-their-incandescent-turn-signal-bulbs.html
Old Mar 21, 2008 | 01:20 PM
Phil Swagger's Avatar
actually just ordered some LED turn signals from Ebay. I dont like the orange reflection in my headlights.
Old Mar 21, 2008 | 01:25 PM
speedracerg35's Avatar
most modern cars indicate a burned out light with a fast blinking turn indicator. you need to wire up the proper resistors.
Old Mar 21, 2008 | 01:52 PM
ttrank's Avatar
Grocery getter
Yes, if you follow the link I put above it has links to some great bulbs (brighter than the oem) and the proper resistors to wire to keep the warning lights off.
Old Mar 21, 2008 | 09:39 PM
wiredup's Avatar
did you have to hack up the wiring to the bulbs or were the resisters plug and play?
Old Mar 21, 2008 | 10:18 PM
ttrank's Avatar
Grocery getter
A little wiring but it's very easy.
Muski_G
Dec 1, 2023 11:11 AM
rezendvous420
May 31, 2020 01:26 PM
MT6002
Lighting
Jul 21, 2015 01:13 PM
attarday
Jul 15, 2015 04:03 PM
