Induction flush at the dealer
Old Jun 4, 2008 | 01:30 AM
gymcshoe's Avatar
went in for an oil change and since i'm close to 25k miles, they recommended an induction flush for $139. has anyone paid for this? is it worth it?
Old Jun 4, 2008 | 02:07 AM
d280c's Avatar
Sounds like a glorified Throttle body/intake cleaning, priced at cleaning out you wallet too.
Old Jun 4, 2008 | 03:00 AM
jsmonet's Avatar
induction flush? lol, does that involve warm yogurt, a rubber bladder, some rubber hose, some lube, and a toilet?
Old Jun 4, 2008 | 01:56 PM
silverG2007's Avatar
If you're worried about dirty injectors, get a $5 bottle of Techron at the local parts store and follow the directions.
Old Jun 4, 2008 | 02:02 PM
jsmonet's Avatar
induction means air intake, fyi
Old Jun 4, 2008 | 03:10 PM
ugaexploder's Avatar
i would recommend something like that at 50k not at 25k...it is a precaution but still not necessary
Old Jun 4, 2008 | 11:19 PM
True. But in this case, "induction service" includes much more.
From: http://www.bgfox.com/mostwanted/fuel-air.html
"Fuel Air Induction Service
Service need: Deposits accumulate on intake valves, injectors, ports, fuel injectors, and combustion chambers, causing loss of power, rough idle, hesitation, misfire, pinging, knocking, mileage and hard starting.
Solution:
Clean fuel injectors
Clean throttle body
Clean plenum and air intake
Clean intake valves and ports
Correct balance of fuel and air in system
Result:
Reduced emissions
Restore horsepower
Increased fuel economy
Starts and idles smooth and runs quieter "
If you don't have, "loss of power, rough idle, hesitation, misfire, pinging, knocking, mileage and hard starting....." you probably don't need the service.
Sea Foam is another "do it yourself" solution. I've never used it, but many swear by it.
jeffbdye
Jun 1, 2018 03:51 PM
f22raptor
Mar 18, 2016 08:50 AM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
Gabe83714
Oct 6, 2015 06:40 AM
