Bad seals? Water in doors after washing.
Old Oct 13, 2008 | 12:50 PM
CardiffJasper's Avatar
I think I may be overly critical and would like a second opinion.
Are my door seals bad and should I get them replaced?
I have a black 08 G35 sedan that I bought new in July. Every time I wash it there is water in the doors. If I open the doors water drops get onto the other doors. Also if I roll down the windows up to 20 min later it streaks them. No water gets into the interior but a lot of water is is in the area that is closed (by kick plates) in all 4 doors and trunk.
This is the first "non beater" car that I have ever owned so I really would like other opinions.
thanks
Old Oct 13, 2008 | 02:21 PM
ANMVQ's Avatar
Your gonna get some water in the door and trunk wells the car is not air tight.
The streaking if the windows is from the rubber still being wet from the wash.
You are ok, as long is there is no water inside the door( In the panel) which is what you have a issue with not just in were the kick plate is.
Old Oct 13, 2008 | 02:23 PM
Great thanks
Old Oct 13, 2008 | 02:24 PM
ANMVQ's Avatar
Sure no problem.
Old Oct 13, 2008 | 03:07 PM
G35Now!'s Avatar
Moderation-free
+1 If you're seeing water inside the passenger compartment, that could be a problem. What you should be seeing though, is water in the doors at the corners (outside the rubber seals), and water on the outside of the windows if you roll them down.
mike730
Jan 12, 2018 04:25 PM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
joedaddy1
Jul 28, 2015 02:58 PM
will091195
Jul 27, 2015 09:19 PM
newg37
Jul 26, 2015 09:32 AM
