OMG! - G37 ruined my dream!
Old Dec 22, 2008 | 02:47 PM
  #31
G37USR's Avatar
Nope the is350 is slower then both. The 335i has a .01 0-60 time on the G37. My freind raced a IS350, with this 335i and beat it buy 2 cars. And thier is also a story on bmw website a guy with his 335i and his freind's wit the G37 and Is350 races and the Is350 was slowest out of both. And he also said he would get the G37 of the line, but then the G37 would speed up and pass him a little, he thought it was modded but it wasn't haa.
Old Dec 22, 2008 | 03:11 PM
  #32
WUKILLABEEZ's Avatar
How old are you? 13? All you do is spout stuff off the top of your head. I gave you track times for the cars from the same magazine and you still say the IS350 is slower? It would be a driver's race between a 335i, IS350, G37 or G35 for that matter. All of these cars run similar times (esp. if you compare times from different sources). You are a big time G37 FANBOY!!! You are hilarious and have a lot to learn about cars esp. the one you want to buy and it's direct competitors...
Old Dec 22, 2008 | 03:20 PM
  #33
G37USR's Avatar
U and ur ****ing sources go grow up, and see an actual race between the cars. rather then posting crap.
Old Dec 22, 2008 | 03:49 PM
  #34
You are the one posting crap. A race between two cars tells us absolutely nothing dum****!!!! All it tells us is one driver can drive better than the other driver since the cars all have very comparable performance. When a magazine tests a car they do multiple 0-60 runs, multiple 1/4 miles, multiple skidpad, slalom, etc...etc... and take the average of those tests to come up with the performance numbers they provide. That is a lot more reliable than watching two drivers of different abilities race cars. Grow up! You have watched The Fast and Furious too many times! You're so funny but it's shocking how little you know about cars, not to mention how little you know about how to research and cite real info instead of your own misguided opinions... I VOTE TO BAN this ******** idiot!!! Anybody else with me?
Old Dec 22, 2008 | 03:52 PM
  #35
ShanesG's Avatar
WTF your post makes no sense!
Old Dec 24, 2008 | 07:49 PM
  #36
MM_G3520's Avatar
I don't like how ppl say 2lbs less torque is bad, u get much better tranny, and G37 does 0-60 in 5.0sec while the G35 does 0-60 5.6. And you will save much more gas with the new 7/at you will save gas, and smoke any stock g35 on the road unless it F/I. The new g37's are as fast as twinturbo 335i, and IS350 and gets better gas then both, 18/28 and it 15k less.
Don't forget that the extra ratios do wonders for torque multiplication. The 7 speed adds so much more. It will surely even faster up top than the G35.
Originally Posted by mal_TX
The G37 doesn't ACTUALLY have less torque anyways... it has less PEAK torque. Across the rev range it has significantly MORE torque, and that's EXACTLY how it gets more HP, seeing as the red line is the same @ 7500 and HP is merely a calculation based on RPM * torque.
Couple that increase in "area under the curve" with the new transmission that has two extra gears (resulting in greater torque multiplication at the wheels from the shorter gears) and I assure you that noone driving a G37 will wish they had a G35 so they could have a couple of ft-lbs more peak torque.
+1
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Rinaldi
Dec 2, 2015 05:29 PM
