maintenance tire question??
Old Dec 23, 2008 | 05:56 PM
gboo559's Avatar
So everytime I start up my G, it says maintenance tire on the dash.
At first I thought the air pressure would be low or something but it wasn't.
Not sure if the dealer is open tomorrow and IDK what to do.
What does this mean?
Old Dec 23, 2008 | 07:42 PM
kregg's Avatar
The only sensor we have in regards to tires are for pressure. So if pressure is good then it wouldnt be for that.
What you are describing sounds like the typical reminder that is set to go off at certain mileage intervals to remind to have tires rotated. Check your wear bars at all four corners, if are flush to the rest of the tire get them replaced. If all bars are bleow the surface but the rears have significantly less wear than the fronts have them rotated. If you arent comfortable with doing this take them to a shop, but really simple to do, or find out how with little searching.
derres
Aug 28, 2015 03:27 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Mac8008
Aug 4, 2015 09:19 PM
korfak
Jul 20, 2015 12:10 PM
