Paint Chip Repair Kit
Old Apr 14, 2009 | 02:52 PM
  #31
Jeff92se's Avatar
Red Card Crew
How about if you do it more than once?
Old Apr 14, 2009 | 02:57 PM
  #32
Texasscout's Avatar
May try that, but it looks like it will take 3 to 5 times to fill it.
Old Apr 14, 2009 | 04:48 PM
  #33
dohturdima's Avatar
Originally Posted by Texasscout
I used mine yesterday. I was not impressed. Paint matched fairly well, technique was easy to use, HOWEVER, it DID NOT fill the paint chip level with the surrounding paint. It covered just fine, and the chips are MUCH less noticeable than before, but the repair does NOT "disappear".
One more thing, it does NOT work well when the chip is all the way to the bare metal and there is minor rusting on the surface. Too much of the paint is removed when you "smear" it.
"Much less noticeable" is what I am aiming for (perfect for mild/moderate bumper rash). If it doesn't work out, it'll be time to call the pros for a respray and then use that butt-ugly bumper guard when parking on the city streets
Old Apr 15, 2009 | 11:57 AM
  #34
Texasscout's Avatar
This stuff should work well on NON-Metalic paints, like black.
Old Apr 15, 2009 | 01:14 PM
  #35
jran76's Avatar
Originally Posted by AesonVirus
This is the stuff I was pointed to...
http://www.langka.com/
I have some of this stuff. I am going to try it out in the next week, or so. I will report back with results.
It is similar to the Dr. Colorchip product, but it uses the factory touch-up paint (which I feel better about using). You basically apply the factory touch-up paint, which will leave a small "blob" of paint, and let it dry. It comes with a small plastic scraper and solution that remove the blob of touch-up paint, but leaves the paint in the chip or scratch. It had pretty good reviews from those that used it. In the end it costs about the same as other similar products. It is $30-40, and the factory touch-up paint is about $12 from the dealer.
I hope to have (good) results soon....
Old Oct 13, 2009 | 11:02 PM
  #36
laksjd84's Avatar
Updates?
Old Oct 13, 2009 | 11:44 PM
  #37
Greekboy115's Avatar
Originally Posted by laksjd84
Updates?
+1! My front bumper is filled with rock chips and was thinking about trying one of these babies out before I end up re-painting the entire bumper.
Old Oct 14, 2009 | 11:26 AM
  #38
AesonVirus's Avatar
A fellow G35 driving friend here at work bought the same kit and he has yet to try it out.
I offered him $5- for it LOL... he didn't take the offer.
It's better than it just sitting on a shelf not being used, right?
Old Oct 14, 2009 | 02:31 PM
  #39
dohturdima's Avatar
If you have metallic paint, my advice is not to use the Dr. Colorchip (unless it's a tiny chip). It will stand out and will look worse than if you hadn't done anything. Just cough up some and take it to a pro.
Old Oct 15, 2009 | 07:39 AM
  #40
Texasscout's Avatar
Mine covered quite well.
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
rsingerG35
Aug 18, 2015 10:16 AM
slider_ua
Jul 29, 2015 04:17 PM
emorehs
Jul 17, 2015 09:45 AM
