Sooo excited
Old Apr 2, 2009 | 06:48 PM
  #31
KulG35's Avatar
I'm frickin stoked!!!! I need to find two front tires! I wonder what size... I don't think that guy had the right size one there. Do you still have the list of tires sizes and rims? I need to see what tires people put on the 19" 8.5 and 9.5
Old Apr 2, 2009 | 06:55 PM
  #32
boss81's Avatar
I have 245/35/19s on my fronts, and I have a 8.5 rim.
  #33
2GoRNot2G's Avatar
What's your rear tire size, Travis? I'm guessing you probably have either 265/35R19's or 275/35R19's on the rear. If this is the case, then 245/40R19's on the front should be a good match.
Old Apr 2, 2009 | 07:03 PM
  #34
2GoRNot2G's Avatar
Really?!?! 245/35R19's are quite a bit smaller in diameter than the factory tires. What size are you running in the rear, Will?
The stock 225/50R18's have a rolling diameter of ~27", and depending on what kind of tire you have, a 245/35R19 is about 25.8", so at least an entire inch smaller in diameter. A 245/40R19 is about 26.8", so it would be a much closer match.
Old Apr 2, 2009 | 08:22 PM
  #35
KulG35's Avatar
Current front tires are 245/35/19 and rear is 275/35/19... I wanted to make sure the tire sizes are correct. front is 19 x 8.5 and rear is 19 x 9.5
Old Apr 2, 2009 | 08:23 PM
  #36
J2S2M's Avatar
I had 8.5F and 9.5R.. ran T1Rs in 245/40 19 in the front and 275/35 19 in the rear. I think that's the closest you'll be to OEM sizes.
Anxious to see what your car's gonna look like. I'm jealous!
Old Apr 2, 2009 | 08:27 PM
  #37
J2S2M's Avatar
Those aren't "WRONG" sizes Travis. A lot of people run that set up for your diameter rims. It all depends on tire brands also.. b/c certain brands don't make certain sizes.
IMO your current set up should be fine. I wouldn't get new tires unless you really HAVE to due to the wear.
GL.
Old Apr 2, 2009 | 08:31 PM
  #38
KulG35's Avatar
Ya, the guy jacked me.... there were in bags and just looks at rims, when I got home the side wall of the front was torn and need to be replace and he was an @$$ about it...still good deal I guess. I think I'm going to be some fronts and just mount :-) I'm getting too excited, first set of rims ever!
Old Apr 2, 2009 | 08:35 PM
  #39
2GoRNot2G's Avatar
Since your replacing the rims anyway, then your defintely better off going with the 245/40R19's. They will match the overall rolling diameter of the stock tires the most closely and there will be no chance that they might throw off your ABS system.
Old Apr 3, 2009 | 01:21 PM
  #40
boss81's Avatar
I hav 275/35/19s in the rear
Old Apr 6, 2009 | 08:57 PM
  #41
2GoRNot2G's Avatar
So, where are the pics, Travis!!!! We need pics!!
Old Apr 6, 2009 | 09:02 PM
  #42
boss81's Avatar
I want pics
Old Apr 6, 2009 | 09:09 PM
  #43
2GoRNot2G's Avatar
Yes, my too, Will!!! He's got everything on now except the wheels, as he still needs to get some new front tires first. The car looks great, but I hardly got to see it all done before he left yesterday, so he needs to post up some pics for us all to see.
Old Apr 6, 2009 | 11:08 PM
  #44
dwdaewu's Avatar
GL.
That set up is fine, i have the same sizes on my volks, theres plenty of sidewall to protect the rim just in case you rub against the curb+enough tire to protect the rim from getting bent when hitting potholes as well.
Old Apr 7, 2009 | 01:25 AM
  #45
KulG35's Avatar
camera is broke!!! you said other were taking pictures, ask them
Trying to find tires now... I owe taxes which is whack!!! So hopefully won't prolong too much
