help with ticking noise coming from rear caliper
Old Apr 21, 2009 | 08:29 PM
puga's Avatar
I recently changed my brakes and turned my rotors front and back of my 07 sedan. I have this ticking noise coming from the rear caliper on the driver side. I've checked everything and everything is tight. The ticking happens when im about half way on the brake pedal all the way to a complete stop. Any ideas of what I should check? Any help is appreciated.
Old Apr 22, 2009 | 11:53 AM
ugaexploder's Avatar
it's probably something stuck in the rear....same thing happened to me, it was a twig
Old Apr 22, 2009 | 04:09 PM
kool_yaar's Avatar
sounds like the dust shield is touching the rotors VERY lightly else you would hear loud screeching, the shield might have been bent in a bit during the brake change process, its the plate right behind the rotors check to make sure its not touching the rotors at all/
rezendvous420
May 31, 2020 01:26 PM
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
Harman Singh
2nd Gen (V36) Sedan
Jul 30, 2015 03:39 PM
atk08
Jul 30, 2015 03:12 PM
