pwr front and rear windows w/one-touch up/down
Old Sep 21, 2009 | 07:20 PM
highend's Avatar
G35xS 2008 with the option (pwr front and rear windows w/one-touch up/down).
Driver side Power front window w/one-touch (up ONLY) STOP to work this morning. All 3 others sides works fine in all directions. Is any way EZ fix on this issue, or only dealer assistants should be on it?
Old Sep 21, 2009 | 07:28 PM
kvangil's Avatar
You should still be under warranty. Don't waste your time, just take it to the dealer.
Old Sep 21, 2009 | 07:48 PM
G35JPP's Avatar
No dealer assistance needed. You just need to reprogram the auto up/down feature because you accidentally disabled it.
Here's what you need to do:
1. lower the window all the way down and then continue holding the switch for 3 seconds.
2. raise the window all the way up and then continue holding the switch for 3 seconds.
This should take care of it
Old Sep 21, 2009 | 07:57 PM
highend's Avatar
Thank you, I will try in 30 min and i let you know. Thanks again.
Old Sep 21, 2009 | 08:38 PM
AesonVirus's Avatar
Yep, that should do it.
Old Sep 21, 2009 | 10:06 PM
highend's Avatar
Yes is working!
Thank you guys for attentions and help!
Old Sep 21, 2009 | 10:10 PM
Greekboy115's Avatar
I take it you got it all sorted out man. This happened to me as well when I unplugged the battery to put in my grounding kit. Luckily, I saw it in a thread somewhere before and knew how to reset the windows.
Th611
Oct 27, 2015 03:48 PM
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
st33zygill
Jul 29, 2015 10:05 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
