Need Help with idling issue
Old Jun 3, 2010 | 12:48 AM
Iilac's Avatar
Dunno if this is normal with other owners but when you start the car in the morning and you let it warm up until tach drops to ~1k rpm. I can feel small vibrations throughout the whole car. I have a 6mt if that matters but I wanted to know if this is the cold start problem that is corrected by the cold start tsb. Your help is great apprieciated.
Old Jun 3, 2010 | 03:58 PM
dohturdima's Avatar
https://g35driver.com/forums/v36-diy...le-bodies.html
Old Jun 3, 2010 | 04:29 PM
Iilac's Avatar
Thanks for the link but my idle is not fluctuating. It just shivers around the 1k rpm only on cold start idle.
Old Jun 3, 2010 | 10:34 PM
kool_yaar's Avatar
^theres a TSB for that, check infinitihelp for something around the lines of "cold engine start rpm" or something. and also clean you TB, i had the same issue and this combo did the trick.
junon
Jan 14, 2023 09:37 PM
esotericrider
Feb 14, 2022 07:19 AM
champppy
Mar 31, 2020 12:25 PM
Silver tiburon
Sep 4, 2015 07:17 PM
All G'd Up
Aug 29, 2015 12:40 AM
