cruise control is borked?
Old Jul 28, 2010 | 02:25 PM
muyrec's Avatar
Anyone else had this happened to them? Turn on cruise control then if you press the VDC button off the little screen in the middle on the cluster starts to flicker. Not the entire screen but the section where you select how far you want the sensor to sense. Goes away when you turn cruise off.
Old Jul 28, 2010 | 02:38 PM
AesonVirus's Avatar
Do you have ICC?
I believe ICC is disabled when VDC is turned off.
It's also disabled if your wipers are turned to low or high speeds.
Old Jul 28, 2010 | 02:48 PM
muyrec's Avatar
ah yea icc is on my car. That's what was i thinking. it disables it.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
markbilo
Sep 30, 2015 01:33 AM
