Front License plate ideas?
Old Aug 9, 2010 | 03:03 PM
cooleststan's Avatar
Hey guys I just got an 07 g35x, unfortunately it came with the front license plate bracket installed. I have the old MA plates so I only have to have 1 plate in the back. Any ideas for what I should put in the front?
I was thinking about this, but it might be a little too repeititve with all of the infiniti logos.
http://cgi.ebay.com/Infiniti-3D-Logo-Black-steel-License-Plate-M35-/170402624025?pt=LH_DefaultDomain_0
I don't want to remove the bracket because then I will have 2 holes in the front. What have you guys done?
Old Aug 9, 2010 | 03:06 PM
TheTrance's Avatar
how about http://www.bumperplugs.com/BPindex.html or have the holes filled and painted?
Old Aug 9, 2010 | 04:53 PM
Defratos's Avatar
You're Despicable
I remember seeing someone on here who had some transparent plugs put into those holes, dunno where to find the thread though
Old Aug 9, 2010 | 05:22 PM
JaxG's Avatar
Def plugs.. Front plates are tacky if its not required.
Old Aug 9, 2010 | 07:01 PM
admdavid's Avatar
They're tacky even when required. LOL
Old Aug 9, 2010 | 08:41 PM
mikeb2's Avatar
I took a couple of plastic pop-rivets and put those in the holes. Then painted them with touchup paint. Looks kinda okay but alot cheaper than $25.00 plugs.
Mike
Old Aug 9, 2010 | 08:48 PM
mike5411's Avatar
bumperplugs.com
(i have no affiliation with them nor have i ever ordered from them. i have heard that they offer plugs in infiniti colors)
Old Aug 9, 2010 | 09:08 PM
uu1runner's Avatar
I thought about the plugs....problem is the bracket left some minor scratches on the bumper where it rubbed against it.
Old Aug 9, 2010 | 10:20 PM
salvador312's Avatar
You should black out the grille and infiniti logo. Then put license plate from ebay. What color is your car?
Old Aug 9, 2010 | 11:53 PM
it is metallic blue slate (not sure if this is the official name) with tan interior (kind of a chick car).
BTW, I took off the bracket, and I'm just gonna paint over the holes. If that doesn't look good, I guess I'll invest in some bumperplugs.
What else do you guys suggest I do with this color? Im thinking of tinting all the windows and getting smoke tail lights. That should look good, no?
Old Aug 10, 2010 | 01:29 AM
07BlackonBlack's Avatar
2007 INFINITI G35 2DR
STILLEN Front License Plate Bracket
If you own a Nissan or Infiniti and do not want to put holes in your front end or fascia in order to mount your front license plate, then this kit was developed for you!
This kit installs on selected vehicles where the factory tow-hook is screwed in (accessed through the factory grille), or in some cases you remove the plug on your factory fascia to install this relocator kit.
It's as quick & easy to remove as it is to install, making it perfect for shows & other situations where having a front plate just wouldn't look right.
www.stillen.com
Old Sep 4, 2010 | 03:03 PM
CJN8's Avatar
I did not see a stillen license plate bracket that would fit a 2006 sedan, what gives, does stillen make one?
Old Sep 4, 2010 | 03:47 PM
terfer's Avatar
Where can you get plugs?? Not $25 ones lol
Old Sep 24, 2010 | 07:04 PM
Leader4u's Avatar
I agree with the other poster. Spend $10 on a tube of touch up paint from the dealer (good to have anyways) and $1 on some plugs from your local hardware or auto parts store. I put mine on a cardboard box (cut a small slit and insert the posts part way) and painted them with 3 or 4 coats of paint. The paint will smooth out on it's own and if you apply it cross ways with each coat (horizontal strokes one time, vertical strokes the next) you will have almost no brush marks. Pop 'em in when they are good and dry and they will look just as good as the $25 plugs!
Old Sep 24, 2010 | 11:47 PM
johnbanks2's Avatar
I like front license plate, and i like doubling the logo . or having one that says get out of the fast lane a hole
