Help on Rims
Old Aug 10, 2010 | 06:07 PM
ChinkyChoy's Avatar
Help on Rims
I did some searching on google and the forums and even scrolled through hundreds of pics to find rims that would look good on my G that is within my price range, but still no luck...
I drive a 08 G35x and after reading some posts about rims i know that i should not go staggered and that i should keep the other dimensions as close as possible to my OEM wheels because of the VDC and AWD
I have a Liq Plat 08 G35x the grill is blacked out and i will be blacking out the headlights as well. i would like to keep the prices under 1.5k.
Just want something to turn heads (not like the G doesn't already) nothing too flashy
Here are some pics of my car
I was looking into ENKEI and XXR, but i dont know how those rims are.
I am looking for any suggestions
Thanks!
Old Aug 10, 2010 | 06:15 PM
J2S2M's Avatar
Look into Forgestar F14's. They are fairly light for the spec and should be within your price range. Also, used wheels are a great option as well. Try searching in the marketplace and also on other forums such as myg37.com since the sedan offsets are similar to the newer coupes.
Good luck w/ ur search!
Old Aug 10, 2010 | 06:24 PM
rpm&my_G35's Avatar
Did you try websites like tirerack.com where you can pick and see the wheels on your car?
I am pretty sure you can run a staggered setup as long as all 4 tires have the same circumference. It just makes it very difficult to rotate them to keep the tire wear even as required for any AWD vehicle. With all 4 tires the same size you can typically make them last longer.
Old Aug 10, 2010 | 10:33 PM
blnewt's Avatar
There's some pretty good deals on some 18" sport wheels (from the 07-08s) in the marketplace. I always like the look of those on the sedans, classy but not too flashy. The staggered setup WILL work on your X as far as diameter goes, not sure about the offsets though. I'm sure it's been done.
Old Aug 11, 2010 | 12:08 PM
djfarhan's Avatar
same here, i cant find any set of rims that i like for the life of it!
Old Aug 11, 2010 | 05:49 PM
Triton3.5's Avatar
Some of the Enkei ( racing line) of wheels, were very sharp looking and light, I almost bought them instead of the OZ ulltraleggera's 18x8's i ended up with,, So i went through tirerack, and got the whole set with Kuhmo's 245/45/18' for $2000.00
Old Aug 11, 2010 | 07:39 PM
madmax2k1's Avatar
Can people with 18" aftermarket rims post pics? I'm not interested in going to bigger rims since I don't want to lower my car.
Old Aug 12, 2010 | 11:43 PM
ChinkyChoy's Avatar
so i looked through tirerack and i came up with some options and was wondering if you all heard anything about these wheels or would like to throw you 2 cents on how the G would look with the rims or any other rims.
Again i am open for all opinions!!!
EV5
PF01
GTC01
If anyone has pics of their G with these rims that would be greatly appreciated!!!
Old Aug 12, 2010 | 11:45 PM
djfarhan's Avatar
^ hmmm
Old Aug 12, 2010 | 11:46 PM
lefizzet's Avatar
That's completely false. I have an x and run a staggered setup perfectly fine, just use a tire calculator and do your research on dimensions etc.
Old Aug 12, 2010 | 11:50 PM
djfarhan's Avatar
^ haha i am gonna need ur help..;-P
Old Aug 12, 2010 | 11:59 PM
lefizzet's Avatar
Sure, send me Pm's with any questions and I'll see if I can help
Old Aug 13, 2010 | 12:03 AM
djfarhan's Avatar
u the man!
Old Aug 13, 2010 | 12:04 AM
ChinkyChoy's Avatar
i m not saying staggered on an X is impossible or wrong i just dont want to run the risk of anything going bad but its just after reading threads like this that throw me for a complete loop...
https://g35driver.com/forums/v36-bra...ct-my-vdc.html
http://myg37.com/forums/wheels-and-t...s-and-awd.html
i m with you on that one
Old Aug 13, 2010 | 12:56 AM
lefizzet's Avatar
From what I know I'll explain in a nutshell. VDC can't tell how wide your tires are, it only tracks circumference/rolling diameter. With that being said, I'll use my setup as an example. Front tires are 245/35/20 rear tires are 285/30/20. Plug that into a tire calculator and you get this:
Look at the first two columns for 245/35/20 and 285/30/20 then find circumference/diameter. If you notice, they are nearly identical, a difference of ~1-2 mm which is nothing. The rule of thumb is to have no more than a ~1-3% difference for a staggered setup. Also, if you note the 3rd column, most people who run staggered 20's (usually f8.5 r10) run 245 in the front and 275 in the rear. Reason I chose 285 was because the dimensions on the 285 are more identical to the 245 compared to the 275. Hope this helps.
