varrstoen question
Old Aug 14, 2010 | 10:58 AM
zoop425's Avatar
varrstoen question
I have a 07 x and Im looking into buying varrstoen's, I would like 19's but Im not sure if I can achieve the same rolling diameter with them as the stock wheels and tires. If someone can let me know which size 18 or 19 I need to get with what offset that would be really helpful. Also, everyone says something different, can I use wider rims and tires in the back? Can I use 9.5 in the back and 8.5 in the front on the all wheel drive model? thanks!
Old Aug 14, 2010 | 11:13 AM
Locksmith's Avatar
You can run 19's without any issues, they don't need to be the exact same rolling diameter as stock wheels/tires they just have to be the same rolling diameter between the new front and rear wheels. Yes you can run 9.5 and 8.5 but the rolling diameter of the overall wheel/tire combo must be nearly the same.
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
UT G35
Sep 3, 2015 03:58 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
