Installing momo auto shift knob
Old Aug 27, 2010 | 04:23 PM
greekgod544's Avatar
Installing momo auto shift ****
Hey everyone, I finally got my momo automatic shift **** in today. A couple days ago I saw a thread on how to install it, but I can't find it anymore. Can someone help me on how to install the shift **** to my 07 g35 sedan
Old Aug 27, 2010 | 07:37 PM
AesonVirus's Avatar
To uninstall the OEM ****, Pull the ring down on the boot and then yank out the little retaining clip.
To install the new, repeat those steps in reverse.
Once you pull the boot down, you'll see that it's pretty easy.
Old Aug 27, 2010 | 07:42 PM
see I did that, but i'm having a problem with putting in the momo. it's not working with me
Old Aug 27, 2010 | 08:28 PM
AesonVirus's Avatar
Hmm... I don't know then, sorry.
I know that when we install the M45 shift ****, the grooves for the retaining clip are in a different spot, so new grooves need to be filed in.
All I can suggest without seeing what you are going through is to make sure the grooves line up.
Otherwise...
Old Aug 27, 2010 | 08:30 PM
AesonVirus's Avatar
This guy has one... it's up to you if you want to ask him for help
https://g35driver.com/forums/media-s...hift-****.html
Old Aug 27, 2010 | 09:22 PM
thanks guys. i kept trying and finally I got the shift ****, but now the problem is when i put the car in park and i shut the door it has a very annoying buzzing sound and I looked at the dash and it says P with an arrow up which means put in park but it is in park. This is very confusing
Old Aug 27, 2010 | 11:17 PM
JSG's Avatar
JSG
I just installed a Momo shift **** in my vette and had a similar situation until I adjusted the height of the momo shift **** on the stock assembly. I had to move the shift **** up a bit to allow the stock rod to fully extend when the **** is at rest. The Momo **** I'm using is the universal one that utilizes set screws at the bottom to secure it to the stock base assembly so it's easy to adjust the height. Hope this helps.
John
Old Aug 27, 2010 | 11:23 PM
when i put the 3 screws the secure it I could not screw in the bottom chrome piece to the shift **** that twists on the bottom
Old Aug 27, 2010 | 11:55 PM
JSG's Avatar
JSG
Me either so I did not use the chrome piece, just pulled the shift boot over the bottom portion with the three set screws in it.
Old Aug 24, 2013 | 04:57 PM
rdavis's Avatar
2005 g35 with leather shift boot.Put car in neutral take off clip and blue insert. Then unscrew the top of the shift **** and put the leather boot inside the shift ****.. then tighten screws... then put spring back in and tighten top and your done
jsimonk
Dec 22, 2023 03:49 PM
JG_G35
Accessories
Feb 25, 2016 01:44 AM
G35fromPA
Interior
21
Sep 20, 2015 08:58 AM
z_spec
West
Aug 13, 2015 07:38 PM
nervseele
Jul 17, 2015 11:21 PM
