Nokya Yellow Fog fitting problem?
Old Sep 11, 2010 | 08:17 PM
TotalledCL's Avatar
Exclamation Nokya Yellow Fog fitting problem?
Hey guys, I was trying to install the Nokya Yellow 9006 bulb to my fogs. I was having a little hard time to get the stock 9006 light out, but after some jiggling, it came out.
However, when I tried to install the Nokya lights in, seems like I couldnt fit the light into the 3 leg fitting. After an hour of jiggling and pushing, I cannot turn and have it lock. At the end, I had to install the stock 9006 back in without a problem.
Am i doing something wrong here? Or Nokya lights do have a little fitting issue? Or anyone have any special way to get it in?
I was using this method to install.. http://krausewhatever.blogspot.com/2...s-in-2008.html it seems to work if the bulb would turn and lock..
Thanks guys!
Edit/Delete Message
Old Sep 11, 2010 | 09:55 PM
04G35NYC's Avatar
You shouldn't have a problem with them, a friend of mine installed them with no problems.
Old Sep 11, 2010 | 11:41 PM
mishmosh's Avatar
No problem here.
Old Sep 12, 2010 | 04:47 AM
TotalledCL's Avatar
Unhappy
Hmm then it's interesting. I put the new bulbs in exactly the way I took out the stock bulbs. I cannot make the Nokya bulbs to turn.
First I thought maybe I was not putting them in right. I grabbed the stock lights, install, and took it out back and forth couple times to make sure I was doing it right, sure did, not problem at all.
I tried it one more time with the Nokya lights, seems like it just wont sit in enough for me to turn and lock it.
Any thoughts?
Old Sep 12, 2010 | 08:24 AM
mishmosh's Avatar
Try comparing the notch on both bulb bases. They should be the same. I definitely think the quality control is a notch below on most aftermarket bulbs.
Freddy07g35
Sep 17, 2015 08:53 PM
Tukeeg35
18 Inch
Aug 25, 2015 06:45 PM
Fireman07603
Aug 9, 2015 06:00 PM
attarday
Jul 15, 2015 04:03 PM
