Visiting Dealership Soon -- Thoughts on issues...
Old Dec 11, 2010 | 01:57 PM
cloil's Avatar
Hi All,
I am am taking my 2008 G35 sedan to the dealership soon for them to look at a few things, and I wanted to see if there were any opinions suggestions on these items:
1) My TPMS light is on -- however, the tires are inflated to the correct PSI.
Any thoughts on this issue? I can't get the light to reset
2) Steering wheel moves left to right slightly when braking at higher speeds
I am assuming rotors -- I read somewhere that there may be a TSB for the rotors due to a known defect. Is this true or will I be out of pocket for this?
3) The cover to the cupholder area is completely mis-aligned when closed. There is a large gap from the console area where the seat warmer buttons are and the tip of the cover. The cover is pointing downwards slightly, which is the cause of the gap. It appears that the problem would be fixed if the rubber pads at the bottom of the panel were a little taller.
Has anyone seen this issue and have any correction ideas?
4) The steering wheel rocks slightly left to right when driving approximately 65-70MPH.
I am assuming that this is a balance issue
Thank you all.
Old Dec 11, 2010 | 02:24 PM
blnewt's Avatar
I used to keep my tires inflated around 30-32 PSI and the TPMS light would come on so I just have them at 35PSI and light stays off.
Rotors can be a TSB, shouldn't have to pony up for that one.
Cup alignment, haven't heard others w/ this but if it's not right they should take car of it.
Your wheel going to the right may be alignment, this one will probably be on you.
Good Luck
Old Dec 11, 2010 | 03:05 PM
cloil's Avatar
I just inflated to 35PSI and took it out on the highway for 5 minutes. The indicator light is still on
Old Dec 11, 2010 | 04:33 PM
blnewt's Avatar
Not sure, but there may be a tpms w/ the spare tire, if it's low the light may be coming on, haven't ever checked the manual to see if it has tpms though
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Duffy25
Accessories
Oct 12, 2015 01:45 AM
dseet
Oct 11, 2015 12:40 AM
gqraverice
20 Inch
Sep 29, 2015 05:39 PM
Jay123
Sep 28, 2015 08:42 PM
