Advice/help on bolt by door handle
Old Jan 24, 2011 | 09:49 PM
RhiNoKiLL's Avatar
So I sound deaden my passenger door....but I missed a spot and trying to go back and do it again. But this bolt here just keeps turning! It wont tighten or loosen =(
Body shop quoted me $260 to get it out? wth....
Anyone know what I can do?
Attached Thumbnails Advice/help on bolt by door handle-handle2.jpg
Old Jan 24, 2011 | 10:32 PM
samsizzle's Avatar
weird, is it still within the threads of the metal? maybe if you unscrew everything on the door and give it a firm tug it will dislodge
in for creative answers...
Old Jan 24, 2011 | 10:45 PM
SDFromZtoG's Avatar
Drill it out with a drill bit for metal. You will end up with a bigger hole, but I'm sure you can find a bigger bolt. Good luck.
kool_yaar's Avatar
i had the same problem thanks to Best Buy when they installed my window up/down module and it would not come out no matter how hard i tried. Then i had my mechanic take it out for $10. he could not drill it out cause of all the plastic around it. What he did was to roll down the window jam a screw driver trough the window rubber and jam it into a little metal housing which was where the screw/bolt goes in and which had somehow gotten loose from the door and was just spinning with the bolt. (hope that makes sense)
So basically he jammed a screwdriver CAREFULLY through the window jam onto the little circular silver metal housing that the bolt goes into and then he loosened the bolt while keeping the cap from turning. I could do it myself now since i know what to hold on to, hope this helps you.
G/L
Old Jan 26, 2011 | 11:14 AM
RhiNoKiLL's Avatar
Hmm interesting kool yaar. Did he jam a screw driver to prevent something from moving and turn the bolt... or turn it with the screw driver and prevented the bolt from moving?
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
AuAltima3.5
Sep 13, 2015 10:53 AM
douglas555
Sep 10, 2015 04:48 PM
jbmw002
Sep 3, 2015 08:42 PM
