best intake?!?!?
Old Feb 16, 2011 | 02:18 PM
apexi957's Avatar
best intake?!?!?
Hey guys what's the best intake under $301??? I heard they will give me better mpgs?? And dyno proven 15+hp/torques?? Help me out guys!
Old Feb 16, 2011 | 03:09 PM
Austin713's Avatar
BAHAHA
Old Feb 16, 2011 | 03:20 PM
CITIM1KE's Avatar
I personally just stuck with a ztube and jwt pop charger...just do some searching to look into which intake you'd prefer.
Old Feb 16, 2011 | 03:24 PM
kool_yaar's Avatar
no intake for these cars can give up more than 8-10hp max, there are many dyno's om myg37.com from forum members as well as company's own dynos. Check em out but you will see that on average the gains range from 4-8hp and only a few get close to the 10hp.
If you wanna go for intakes then go for them for sound, looks and even mpg but very low difference if any. I am and have been very happy with R2C
TrixR4kidz's Avatar
intakes pretty much are for sound only and loss of low end power and throttle response on our cars. for 300$ budget id suggest looking for something else.
best bang for the buck is probably going to be replacing your cats with high flow cats or test pipes.
The only intake-ish thing you would ever need is a Ztube.
Ztube: http://www.z1motorsports.com/350_g35...oducts_id=3929
Z1 Test pipes: http://www.z1motorsports.com/350_g35...oducts_id=3373
Also if you want more power id suggest looking into Mrev2 and 5/16 plenum spacer.
Please understand that with aftermarket intakes (even with heat shields) temperatures of the air will be hotter. Especially at idle. when you launch off the line with aftermarket CAI's you can loose up to 15hp at low RPMs because of heat soak at idle.
Id suggest getting friendly with the search button before you get flamed.
Old Feb 16, 2011 | 04:05 PM
RhiNoKiLL's Avatar
this is 2nd gen.... spacers arent for us
Old Feb 16, 2011 | 04:54 PM
TrixR4kidz's Avatar
wow i didnt even realize that.. well then my post failed.
Old Feb 17, 2011 | 09:47 AM
implicitv36's Avatar
z tubes are useless on HR motors.
Old Feb 17, 2011 | 11:18 AM
kool_yaar's Avatar
You want extra HP for cheap?? problem solved . Just read this post from Phalanx...
but seriously though dont buy this.
Old Feb 17, 2011 | 11:35 AM
ChinkyChoy's Avatar
wtf is that????
hahahahaaha
Old Feb 17, 2011 | 11:37 AM
apexi957's Avatar
What about this guys? isn't this like that cooler thing for turbos?
thescreensavers's Avatar
Mr.202?
Want extra power? Put smaller wheels on the front, so your car is like riding on a constant downhill
For the intakes, attach a leaf blower to each of them and finally on the front tow hook attach a big magnet facing the car.
You will be sure to get like 300hp out of this.
Old Feb 17, 2011 | 11:40 AM
apexi957's Avatar
+1 finally someone that understands! What if i add Nismo and Vtech stickers? If the rear wheels are bigger and the front are smaller will there be more power???
Old Feb 17, 2011 | 11:52 AM
herrschaft's Avatar
^Stickers will only add minimal gains, you need to get the Vtech chip combined with some Turbonators...
Whats with all of the serious posts in here???
ChinkyChoy's Avatar
dont forget your ricer wing
with all those ponies you are getting
Heard these add a few HP too
the bigger and flashier these are the more gains!
