2008 G35x w/ navi digital clock way off
Old Feb 23, 2011 | 12:01 PM
CremonaG35x's Avatar
I got in my car this morning to find my clock saying 5:23 when it was really 10:50. I went into my settings and there is no way to the correct time now. Even with the minute offset being +23 or something crazy, not one time zone (im central) made it right either. Anyone know what I can do?
Old Feb 23, 2011 | 12:16 PM
kool_yaar's Avatar
Just set it to the right time zone and it will be fine, the time is automatically set/updated through the satellite, iv only had this happen once in 4yrs due to extreme bad weather but the analog worked fine throughout.
Old Feb 23, 2011 | 12:23 PM
So set my settings accordingly and it will fix itself later today wish a nav refresh or something?
Old Feb 23, 2011 | 12:46 PM
AesonVirus's Avatar
Go to Settings > Clock and then you will have options to set the 12/24 hour format, DST, Offset Adjustment and Time Zone.
The clock should just reflect the correct time, if you ahve the time zone set correctly.
It's difficult to determine if that's your solution without knowing what your time zone is set to and where you are located.
Old Feb 23, 2011 | 02:15 PM
kool_yaar's Avatar
yes it should fix itself just chk your zone like aeson said and you should be set.
keepthebeat
Oct 30, 2007 11:08 PM
gao
Dec 2, 2006 05:17 PM
DavidTSimon
Nov 2, 2006 09:56 PM
blackg35x
Jan 11, 2005 05:06 PM
jdog
Jun 25, 2004 12:04 PM
