Factory shifter replacement
It always takes more than one try to shift from P to D, as the push button on the shift **** seems not able to engage with the mechanics inside and I had to press a few times before I can shift P to D.
Do you guys experience the same with OEM shift ****? If I get the M45 shift ****, does it cure this issue?
https://g35driver.com/forums/media-s...ml#post5721301
Hasanbaloch
Feb 29, 2024 08:45 PM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
BasquiatPicasso
Jul 23, 2015 06:26 PM
