Air from Driver Side Window
Old Mar 21, 2011 | 11:40 AM
jdg5005's Avatar
When im driving in excess of 65 - 70 MPH it sounds like there is a little air leak on the driver's side window and possibly also the sun-roof. I am relatively new to to the g35 (i have an 07x) just wondering if this is common?
Old Mar 21, 2011 | 04:38 PM
soundmike's Avatar
There have been several instances of this issue and you have two of the three possible areas where the air is leaking in. I believe the sunroof one currently has a TSB on it as well.
For the side window, there's a chance it's actually coming in from the rear glass by the C-Pillar. Here's a quick fix-it for it, if you want to try and tackle it yourself.
Old Mar 21, 2011 | 05:46 PM
Bozookah's Avatar
this happened on the coupe too, anyone knows a fix for the coupe?
Old Mar 21, 2011 | 07:00 PM
preston8o8's Avatar
very common problem i have that same issue on my passanger door as well
Old Mar 24, 2011 | 01:53 PM
jdg5005's Avatar
Do you know what the TSB number is for the sunroof?
Old Mar 24, 2011 | 05:31 PM
scorpkev's Avatar
G35 Sedan RWD
I have the same issue from the front driver side only.
Did you had it fixed and what to fix?
mbe093
Lights
Oct 2, 2016 11:09 PM
Ludz
Lights
Mar 28, 2016 02:06 AM
apintojr
Jul 23, 2015 10:52 AM
vstypicals
Jul 20, 2015 10:55 PM
