Driver's side door won't open!?
Old Mar 24, 2011 | 11:55 AM
WxAxGxS's Avatar
I've been trying to search but haven't found anything.
I went to get in my car today and my driver's side door won't open - from inside or out. There's no resistance to the handle (i've played with the manual lock mechanism on the side of the door) and I hear nothing when I use the auto lock/unlock...
Anyone have any idea? Or at least how to open the door when it's in this condition? I busted up my knee yesterday so I can't even climb over the console and I'm supposed to be making a road trip today (as in a few hours ago).
Old Mar 24, 2011 | 11:59 AM
bluedevils95's Avatar
Did you try your key? Or is it jsut the handle? Maybe the wire on the inside of the panel came off. That is the only thing i can think of for now.
Old Mar 24, 2011 | 12:00 PM
WxAxGxS's Avatar
Key doesn't work. The manual locker inside doesn't work. Inside and outside handles have no resistance and when I auto lock/unlock I hear no noise inside the door...
Any way I can get the door open? Can I even remove the panel with the door closed?
Old Mar 24, 2011 | 12:10 PM
I can't think of how to open it but you might want to give the dealers a call and they can help you w/ that. I hope they tell you.
Old Mar 24, 2011 | 12:19 PM
rketchjr's Avatar
You will have to take it the dealer. My car is headed down that path as well. Your locking mechanism is done. Costs around $600 - $800 at the dealer. There are times when my door will only open with the key. I don't hear a noise either when I try to open it elctronically on occassion.
Old Mar 24, 2011 | 06:39 PM
kool_yaar's Avatar
could be a broken wire that connects the handles to the latch.
Old Mar 24, 2011 | 07:34 PM
preston8o8's Avatar
hmm never heard this problem before
Old Mar 24, 2011 | 11:26 PM
Just to replace that wire is between $600 to 800 bucks!!! I would never pay that. I would Jerry rig that before i ever pay that price.
Old Mar 24, 2011 | 11:49 PM
kool_yaar's Avatar
^ i hope thats not true else that is taking it to a whole another level for the stealership... its an easy thing to do, iv done it on a couple of my old cars and it should not be any different, if u confirm its the wire then get it for $20-60 and DIY or have a local mechanic do it.
Old Mar 25, 2011 | 02:35 PM
rketchjr's Avatar
If it is the wire, it shouldn't be that costly to repair. I was told the locking mechanism itself was going bad and not the wiring. Either way, get it checked out sooner than later.
Old Mar 25, 2011 | 03:24 PM
kool_yaar's Avatar
^ but if the locking mechanism was the only thing going bad then in this case he would still feel resistance while pulling on the door handles which is why i believe its the wore it could also be the locking mech. if the remote is not unlocking the door.
Old Mar 25, 2011 | 07:35 PM
WxAxGxS's Avatar
Hey all, sorry for the delayed response (I finally made it to my destination).
After giving up on the car I went inside to throw things around... I called the dealer and they said it was probably a broken wire and would be $300 for the part and $150 for labor (EABOD, dealer, EABOD)... I then went back outside, hit unlock on my key fob and the door magically opened.
It has been working fine since, but I can only assume whatever happened will come back. When I get back home I will probably pull the panel off and take a look inside. I just bought this car (94k miles now) so who knows what has been done to it. I did notice today that there is some clear plastic hanging below the door pinched between the door and panel. Is this normal or has something been done inside before?
Anyway: the real challenge is pulling the panel off the door if you can't get it open. As far as I can tell this isn't even possible (as the trim hangs between the door and the rest of the car). Anyone have any thoughts/insight?
Old Mar 25, 2011 | 07:48 PM
That is still pretty expensive for me. I'll just roll the window down and jump in.
Old Mar 25, 2011 | 07:53 PM
WxAxGxS's Avatar
Difficulty: I just wrecked my knee and can't bend it (probably a torn LCL... will find out next week... diagnosed by myself though as the GP I went to was borderline retarded and I've had more than my fair share of torn/avulsed tendons/ligaments)... Makes getting in and out very hard. I couldn't even make it over the console as I'm 6'3" and there's no doing that without a bit of flexibility.
Old Mar 25, 2011 | 08:58 PM
vqsmile's Avatar
IIRC, they wrap the door panels (or sections of them) in clear plastic at the factory to protect them during shipping. The dealer removes this during the pre-delivery inspection. Sometimes they get sloppy and don't get all of it out.
