some questions about G35x 08 sedan's safety?
does G35x 2008 has auto lock?
if i forgot lock my car,someone can drive my car away without key? (my car has anti theft) btw,if i unlock my car and i leave with my key, the car will flash light or ...? thx for reply and be patient with me... |
dont worry they cant drive off without the key because the key has to be inside for the car to start and even if you left the car on and they drive off with it and you had the key the car would shut off since the key is too far.
and i have no idea about the auto lock lol in for answers too :D |
thx for reply...
no only the 09+ have the auto lock feature in which the doors lock while in drive.
I dont believe any of the G's have the option in which the doors auto lock if you walk away with the fob. |
thx
although there are several aftermarket alarm and security systems that have this feature...i believe one of the more popular ones is the ST800 or something like that.
Quote:
What is the distance for the "shut off" feature? |
i moved my car around the driveway, the key was in the garage, and it was beeping like crazy but still let me move it.
once the car is start you can drive it anywhere, i have driven it a few miles without a key!! I think they have tried to mimic the regular key system, if a regular key ignition car is start then it can be driven anywhere and the same rule applies to our car, however it can not be started without the key.
Also im not sure if it cause of my AM alarm or not but if the car is unlocked and i forget for a while the car locks it self within a few minutes, but im pretty sure it did this before the alaram install as well. |
Quote:
Quote:
if you hit the unlock button on accident and no door is open within a minute, the car will then lock itself.
the next model should have a auto shut off feature as soon as you hit the gas when the car is NOT inside the ride.
thank you..man
Good to know. I thought the car would shut off if someone tried to drive it without the key inside.
| All times are GMT -4. The time now is 01:24 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
