Brake Rotor,Caliper paint.. No more rust :)
Old Jun 24, 2011 | 11:44 AM
jlnvgs's Avatar
Caliper Rust
Is this product enough for all four brake calipers on a 2008 G35XS? Or Do I need 2 cans?
Aerosol 7 oz. 1 hr. 24 hrs. __ 1200° F 50° to 90° F Satin: Metallic Silver 7721T37 15.10
Thank You
Old Jun 26, 2011 | 12:42 AM
Navin R Johnson's Avatar
That is the correct part #7721T37. One can will do all 4 calipers and rotors no problem. Being that the pigment is basically a stainless steel powder it covers very well.. You will use less of this stuff compared to regular paint..Should still have a little extra as well.
Old Jul 18, 2011 | 06:58 PM
jlnvgs's Avatar
Got the paint need torque specs
Purchased the paint but having trouble finding torque specs for the brake caliper mount bracket bolts and sliding pins.Also wheel lugs.I will be removing and painting only the calipers due to replacing the rotors.Any one
know a good link. Thank You.
Old Jul 18, 2011 | 07:29 PM
drivethefive's Avatar
thanks for the detailed info on this diy. Nasty, rusty rotors plague so many G's, I was even watching a video on YouTube for Vertini wheels and a close up on the video showed a great looking G coupe with rusty rotors of all things!
I'll be doing this soon, will post pics before/after bc my rotors look disgusting right now!
Old Jul 18, 2011 | 08:46 PM
PursuitofG's Avatar
thanks I need this!
Old Jul 18, 2011 | 09:27 PM
vqsmile's Avatar
know a good link.
Thank You.
Well, I believe it's gotta in the FSM which is available for free when you register at Infinitihelp.com. Nothing like getting it right from the horse's mouth.
Old Jul 18, 2011 | 10:15 PM
rvanderwerf's Avatar
caliber bolts 132.5 (basically get them on a hard as you can lol)
hex bolt/locating pin 27 (dont overdo it!)
back caliper bolt 24
I did this (twice!) a couple weeks ago
Old Jul 18, 2011 | 10:25 PM
cto917's Avatar
i've been wanting to repaint my calipers silver for awhile now but just havent found the time. but the ease of this makes me wanna do it now!
Old Jan 21, 2012 | 03:28 AM
Manhattan Project G's Avatar
Was looking for a solution to my rust... this is perfect, thanks!
Old Jan 21, 2012 | 03:16 PM
vqsmile's Avatar
Holy crap, how'd I miss this
THIS INFO IS MISLEADING !!!
You are quoting the first newton-meter value. The correct SAE torque values in the manual are the last value given in parenthesis. A typical torque notation format is :
xx N-m ( xx kg-m, xx ft.-lb.) [where the wrench symbol is white with a black background]
xx N-m ( xx kg-m, xx in.-lb.) [where the wrench symbol is black with a white background]
SO, in the case of the mono-piston sport brakes, the listing is shown as: 132.5 ( 14, 98 ) and has a symbol of a white wrench on black background.
This means the torque spec is 98 ft.lbs. If someone tightened to 132 ft.lbs. they'd likely strip or at least stretch the threads on the bolt.
Likewise, the other torque specs you've listed in their newton-meter values as well. Given specs:
24.0 (2.4, 18) , the value should be 18 ft.lbs.
27.5 (2.8, 20) , the value should be 20 ft.lbs.
Hopefully you didn't do it wrong . . . TWICE!
Old Feb 12, 2012 | 04:10 PM
kristof's Avatar
Ill have to try this stuff! Mine are starting to rust and I really dont want to powder coat them since I may be doing a brake swap in the future.
Old May 18, 2013 | 09:41 PM
LI-G35Driver's Avatar
Just to confirm, this stuff is good for spraying rotors? I just put new ones on and they had what looked like rust stains on them within a week.. I used some 0000 steel wool on them and soap and they look completely disgusting now. I need to paint them. lol. This stuff is good to do a full rotor spray?
Old May 18, 2013 | 09:47 PM
Yea, anything touching the pads will wear off when you use them. I sprayed my entire rotors, of course I minimized the amount on the contact area.
Old May 18, 2013 | 10:30 PM
vqsmile's Avatar
^^ +1 . . . Whs
  #30
Good deal... Thanks! Hopefully those rust spots/ dirt gets grinded off in the contact area too! haha.
