2008 G35 incomming calls not registering on Bluetooth
Old Jul 28, 2011 | 03:01 PM
Mymzee's Avatar
Question 2008 G35 incomming calls not registering on Bluetooth
Hi.. This is my first time here and new to the "Infiniti Club".
I just purchased a used 2008 G35S with the NAV package. For the first month my Bluetooth worked great and recently my incoming calls are not registering. I’m getting missed calls since it is not ringing. I tried to access my Incoming Call log but it is disabled (grayed out).. I only have access to my Outgoing Call log.
On the rare occasion that I see my phone is ringing, then I am able to manually answer my cell phone and then the hands free kicks in. Everything else works fine on the BT.
I have tried adjusting the ringer volume on both the cell phone and car settings and have also unpaired my phone and repaired it.
No luck. Any suggestions?
BTW - WOW.. what an excellent car.. I LOOOVE it!
Old Jul 28, 2011 | 06:51 PM
gtbigup01's Avatar
If you have a BlackBerry remove and re-install the battery. Look in the right corner of ur nav screen for the check indicating a phone signal. BB has an issue when if it's dropped it will not pick-up on your car and all is req'd is battery removal and re-installation.
When I say dropped I don't necessarily mean on the floor. eg if you got home and threw your phone on the bed and it bounced around. Don't ask me why I just know it happens. If you don't have a blackberry, well do the procedure anyways as it may work. Iphone? Too bad, no removable battery.
BTW: Welcome
Old Jul 28, 2011 | 09:50 PM
kool_yaar's Avatar
^ whs, this sounds like a BT compatibility issue with the phone but since it used to work fine then its probably what gtbigup said.
Old Jul 29, 2011 | 06:22 AM
GXXXV X's Avatar
i have problems with my BT with my Droid X, like i answer the call and then it goes right back to radio and puts the person back on the phone earpiece
Old Jul 30, 2011 | 08:33 AM
Mymzee's Avatar
REMOVING THE BATTERY WORKED!!! Thank you sooo much!
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
crazy_g35s
Jul 20, 2015 02:30 PM
newbdriver01
Jul 15, 2015 06:10 PM
